Old 12-21-2006, 03:39 AM   #1
skokie
skokie's Avatar
Headlight Relay Install
Those of you that did the headlight relay install where did you mount your relays? Post pics if you got em.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-21-2006, 03:44 AM   #2
nandress
nandress's Avatar
Re: Headlight Relay Install
I don't have a picture, and couldn't get one to turn out very well if I tried, but if this explanation doesn't do you, let me know and I will try.
I mounted mine (along with two fan relays) on the back side of the core support on the driver side down by where the inner fender bolts to the core support. It was a tight fit, but it was out of the way. There was a flat spot that fit all four relays nicely.
nandress is offline   Reply With Quote
Old 12-21-2006, 11:18 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
skokie,
Check this thread out:
http://67-72chevytrucks.com/vboard/s...eadlight+relay
LockDoc
Leon
Old 12-21-2006, 11:52 AM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
I too don't have a picture, but I mounted mine on the core support, behind the battery tray, and with the battery in place, you can't see them. I also made a plastic mounting the plate that all of the relays are screwed onto and then used one of the existing bolt holes on the core support to mount it.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 12-21-2006, 12:48 PM   #5
skokie
skokie's Avatar
John
How did you run your wires on yours?
68 build thread
Old 12-21-2006, 02:59 PM   #6
John Fabris
TOTY 2006
I ran all of the wiring so that it looked like it was stock using the wire gutter along the top of the core support.
I will get some photos tonight when I get home....
John Fabris
67 C10 SWB
Old 12-21-2006, 04:23 PM   #7
skokie
skokie's Avatar
Thanks John. I appreciate that.
68 build thread
Old 12-21-2006, 09:31 PM   #8
Brad
Out of the carpool lane.
Brad's Avatar
Here's how I've mounted mine. Looks like a mess that I need to cleanup.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 12-22-2006, 12:44 AM   #9
John Fabris
TOTY 2006
Here are the pictures of mine. They are hard to see, but hopefully you get the idea...
John Fabris
67 C10 SWB
Old 12-22-2006, 12:47 AM   #10
skokie
skokie's Avatar
John
Yep I see those. Got some more questions for you. Is your wiring new? Also have you noticed if that wiring gets any hotter since you are pushing more through it?
68 build thread
Old 12-22-2006, 01:15 AM   #11
skokie
skokie's Avatar
For the heck of it I took my multi meter out and measured the voltage on the driver side headlight while on high beam I got 13 volt reading from it. And 14.10 out of the alternator. Also I did install a new headlight and engine wiring harness about 6 months ago and I noticed when I installed it that the wires seemed to be 1 guage thicker.
68 build thread
Old 12-22-2006, 01:24 AM   #12
krue
Designated A-hole!
krue's Avatar
I used the relay box out of a dodge dynasty and used the installed relays. I mounted it in place of the voltage regulator, it blends in well with the core support and has spots for 9 relays.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-22-2006, 02:31 AM   #13
nandress
nandress's Avatar
Even when you have the relay you will still probably have about the same voltage drop across your high beam light. The biggest difference is that the juice is going directly to your lights and bypassing all that other stuff, which is beneficial when you are doing other stuff (besides measuring voltage drop across your high beam!) Most headlight relays would have 12 guage or bigger going to the power side of the relay because you will likely have a 30 Amp fuse. But it is more efficient, all the same.
Old 12-22-2006, 03:16 AM   #14
John Fabris
TOTY 2006
skokie, I did use a new wiring harness, E-Z Wire, and instead of the wires from the lightswitch/high-lowbeam to the lights, those wires run to the new relays, and then I had to add new wires from the relays back to the lights.
I have not really tested whether they get hot or not... but I am running a bigger gauge wire from relays to the lights..
John Fabris
67 C10 SWB
