Old 01-07-2007, 09:36 PM   #26
Thunderace1997
Re: New guy with questions, imagine that :-)
Originally Posted by AKChevyman View Post
Every one hot rods 1/2 tons go against the grain like me and hot rod that 3/4
i agree, i don't care what people think but im not sure if the long bed will fit well in the garage. I know the short bed will. my brother has 63 long bed ford and he measured it from bumper to bumper and my garage is 5-6 inches shorter. if anyone has a long bed c/20, could you measure from bumper to bumper. if no one can i'll measure this one im looking at in a couple of days.
Thunderace1997 is offline   Reply With Quote
Old 01-07-2007, 10:20 PM   #27
stsalvage
Scrapper 1
stsalvage's Avatar
Hello longhorn hows life AND HELLO ALL BOTHER TRUCKERS OF THE BOW TIES
WELL i BOUGHT A 1972 3/4 WITH LEAF SPRINGS VIN# CCE242Z158569
BUT LONGHORN EVER SENCE 1967 I HAVE NOT SEEN THE 3RD MEMBER ON ANY OF THE TRUCK AFTER 1967 IN THE 3/4 TON I READ SOME WHERE THEY WANTED TO GO TO THE OTHER REAR END DUE TO WHEN THEY HAD TO DO BRAKES ON THE 1960---1967 YOU HAD TO PULL THE AXLES OUT INSTEAD OF TAKING THE 8 LUG NUTS OFF AND TAKE THE 2 SCREWS OUT AND BANG ON DRUM AND IT SLIDE RIGHT OFF
nOW HERE IN CALIF MOST GUYS WANT THE 3/4 TRUCKS DUE TO THEY HAVE THE BETTER CABS CUS MOST OF THE TIME THEY WHERE STRICKLY USED FOR WORK NOT HORSEING AROUND
I BOUGHT MINE FOR 800.00 WITH VERY LITTLE CANCER IN IT FLOOR IN GRATE SHAPE BUT WITH VERY LITTLE CANCER WHERE THE DOOR SEAL ARE THAT IS WHERE THE BADEST CANCER THERE IS ON ONE SIDE THE DRIVERS SIDE
I'M USING THIS THIS TRUCK FOR MY NEXT WORK TRUCK ITS ALL GOING BACK STOCK IT WILL COST ME $7000.00 TOBRING IT BACK TO BRAND NEW
ALL NEW BUSHINGS ALL THE NEW INTIER NEW HEATER CORE NEW GLASS AND ALL NEW RUBBER ALL NEW WIRE HARNESS NEW HITCH TRAILER BRAKE CONTROLER NEW RADIATOR 4 CORE
SUBBING OUT WORK FOR A CRATE ENG FROM MR GOODWRENCH 249 HP 350 4 BOLT MAIN NEW NOT REBUILT FOR 500.00 AND MY 350 NONE LOCK UP TRANS FOR 600.00 REBUILT THE GUY I KNOW OWNES A DEALER SHIP HIS BOTHER REBUILD TRANSMISSION FOUND A 1963 375HP VETT ENG WITH THE 202 HEADS TRADED IT TO THE ONE THE OWNS THE DEALER SHIP FOR THE LESS PRICE ON THE ENG
THE FENDERS AND FRAME VERY NICE ON THIS 1972 DELUXE C20 POWER STREEING AND BRAKE AND DISC
stsalvage is offline   Reply With Quote
Old 01-07-2007, 10:29 PM   #28
stsalvage
Scrapper 1
stsalvage's Avatar
If You Want To Have A 1/2 Ton I Say Find A 1972--1987 1/2 Ton Ripp Everything From Under The 1972 3/4 Ton And Swap It With The Newer 1/2ton Stuff Save You A Lot Of Time With In 2 Weeks You Can Convert A 3/4 Ton To A 1/2 Ton And You Can Use All The Brake Lines But The Rear End Will Mostly Be Leaf Springs
And Who Ever Said Its Hard To Lower A Leaf Spring Truck I Think They Got It Down To A Art Sence They Have Been Lowering 1985--2006 Leaf Sping Trucks Here In Calif In Coil Springs Its The Same Way Just C Challen The Rear Frame And Get Lowering Spings For The Rear And If You Really Want Anice Set Up You Can Go Throw Curry That Makes The 1/2 Ton Ford 9 Inch Built With All The Ciol Or Leaf Spring Set Up On The Rear End And Have The Rear End Built For You For $2500-3500.00 But Thats Me If I Wanted A Rear End To Take "horse Power" It Will Just From Right In To Channlle And Lower The Truck Cost You At A Lowering Shope 900 --1200 To Use Spin Teck Or Force One Lowering Kitsthats What The Price Is Here In Calif
Old 01-07-2007, 11:14 PM   #29
breeh
Recovering 67-72 Addict
breeh's Avatar
Originally Posted by Thunderace1997 View Post
Just want something that has some balls and can handle somewhat as far as braking and turning.
No problem having something with balls as far as this truck is concerned. However, braking and turning can hardly be put it the same sentence as a 3/4 ton P/U!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 01-07-2007, 11:24 PM   #30
WorkinLonghorn
WorkinLonghorn's Avatar
Tell me about it.When I got mine it had split-rims and tubed bias-plies (6.50x16s i think).Now that I have regular wheels and good radials I can actually go around corners.-cougar
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-08-2007, 01:02 AM   #31
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Seems to me $500 is a great price for a all-one-color driver...try it, you might like it; slider, nice back bumper, bed storage box and a cool rail-thingy on the bedsides! An affordable way of finding out if these trucks are really you. Score the truck then worry about the rearend. You can' lose at that price but figure on finding 18' of parking space. E
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 01-08-2007, 04:43 PM   #32
Thunderace1997
I think I'm gonna buy it. I just might have to take the bed and bumper brackets off to fit the truck in which I would do anyway to start the tear down process.
Old 01-08-2007, 05:41 PM   #33
WorkinLonghorn
Does it happen to come with a licence plate? If you're buying it in the "ghetto" or anywhere else for that matter, make sure the thing is legit before forking over the hard currency.
Some guy GAVE me a VW once and a while later the city came by and put a "Denver Boot" on it and said I had a ton of unpaid parking tickets!
Old 01-08-2007, 10:02 PM   #34
Thunderace1997
lol, that sucks. I have some connections in the PD here and have had the VIN run already. I just found a 65 long bed down the road with an original V8 so if the guy comes with a good price on that, I might have two long bed chevys in my yard soon.....wife is gonna be pissed :-)
Old 01-08-2007, 10:05 PM   #35
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
just remember, it is easier to ask for forgivenes, than permission.
Old 01-08-2007, 10:24 PM   #36
longhorn71
longhorn71's Avatar
lmao......I agree 100%
the eaton rear was used on the 6cyl and smallblock trucks.It is easy to swap it out for a newer rear end tho.It is a great looking truck for that price.I have paid more for a non-runner be for
longhorn71 is offline   Reply With Quote
Old 01-08-2007, 10:24 PM   #37
Thunderace1997
I hear ya. Ive begged for forgiveness several times for toys that ahve mysteriously appeared in the garage :-)
