Old 01-06-2007, 04:09 PM   #26
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Phantom 68 Longhorn with AC and 396&400
Olden Days Did Any Of The Big Block Trucks Come With The High Rise Intake Q Jet Manifold Cus This One Has One On It The Intake Seriel Number# 3883848
stsalvage is offline   Reply With Quote
Old 01-06-2007, 05:08 PM   #27
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I was thinkin of 69 oldie... my fault.
Total brain fart... that 8 that I wasn't recognising...that's the model year. 'duh' I feel like a boogar eating moron.
Lets see, this new VIN;
Ce248z174900
C 2 wheel drive
e v-8
2 3/4 ton
4 cab with bed
8 1968
Z built in Fremont Ca
174900 the 74900 th truck off that assembly plant.
Old 01-06-2007, 05:33 PM   #28
Olden Days
Living In The Past
Olden Days's Avatar
Again I cant find a number to match yours but this one is close. maybe you misread 8 for 9?
3883948 1966-68 396 325 HP L-35 and 427 390 HP L-36
Olden Days is offline   Reply With Quote
Old 01-06-2007, 11:38 PM   #29
72armyswbtruck
72armyswbtruck's Avatar
Originally Posted by Longhorn Man View Post
i've never figured the DD... I think Rod had something on that.
As far as engine castings, I really never bothered learning how to decode engines. I attempted a few times, but said forget it. There's a few ppl here that will chime in... kinda suprised they have not already.
As for the lwb step sides... you need to look at the wheel base too, that's where you are confused on what I was saying. (let me scroll up and make sure it's not my fault)
You read that as no LWB step sides.... I was talking about longhorn wheel base... not regular LWB.
Step sides came in 3 sizes;
6 1/2 ft... only in 115, or 1/2 ton.
8 ft... came in 1/2 ton and 3.4 ton. (there's the LWB step)
9 ft... came in one ton only, and only on the 133 inch wheelbase.
My Bad.......
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-07-2007, 09:48 PM   #30
stsalvage
Scrapper 1
stsalvage's Avatar
Longhorn man you ever get a chance to see if my truck was a true longhorn
Old 01-07-2007, 11:12 PM   #31
Longhorn Man
uh oh.... i don't even remember anyone asking...esp just this month.
Old 01-07-2007, 11:17 PM   #32
WorkinLonghorn
WorkinLonghorn's Avatar
Regardless of any numbers STSalvage,it's a longhorn IF it has a 6 inch section added (and quite visibly welded) to the front of the bed yielding a 102 inch bed.-cougar
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-08-2007, 12:22 AM   #33
FarmTruk
In Memoriam...
FarmTruk's Avatar
hahahhahahahhaha..."boogar eating moron...
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-08-2007, 06:21 PM   #34
dogdaddydbtg
Your casting number doesn't come up. The closest matches are 3935439 : 68-69 427, or 3935440 : 68-69 396 from www.nastyz28.com. They have quite an extensive list of casting numbers.
dogdaddydbtg is offline   Reply With Quote
Old 01-08-2007, 06:30 PM   #35
dogdaddydbtg
As for the intake manifold, areyou sure the number isn't 3883948, this shows up as a 66-68 396 325 hp, which would make sense or a 66-68 427. Either way I don't think this would be the high rise intake since this was the low hp 396.
Old 01-08-2007, 09:50 PM   #36
stsalvage
Scrapper 1
stsalvage's Avatar
thanks just trying to find out one last thing did GM have a casting problem on the 396 blocks in 1968 cus the numbers are back words
