Old 02-04-2007, 01:40 AM   #1
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
stick to automatic swap question
I hve a 68 chevy longbed that had a 6 popper & 3spd stick in it. i'm going to slide in a SBC & 350 turbo long tailshaft tranny.
my question is this other then the yoke on the driveshaft is lenght of the driveshaft different between the 3spd stick trans & the auto???? thanks....joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 02-04-2007, 03:43 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: stick to automatic swap question
im pretty sure it is but i dont know how much
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-04-2007, 07:43 AM   #3
70GMCer
70GMCer's Avatar
I know when I did my swap, I already had a 350 engine in mine w/3spd manual. The 350 turbo I used was the short shaft and hooked right into the drive shaft without any shortening. I think with the long shaft turbo, you will need to cut the drive shaft down, or get a short tail shaft for the trans. It would be cheaper to get the short shaft at a junk yard. Easy change. Someone else can chime in on this. While you're at it, check your speedo gears to make sure your speedometer will be correct.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 02-04-2007, 08:37 AM   #4
70c/10barebone
Junior Member
70c/10barebone's Avatar
Are you planning to mount the sbc in the 6cyl position? I've heard this is common and addresses some peoples drive shaft lenght issues. But that is using short shaft 350 turbo which is the same lenght as the 3sd manual.
70 C/10 LWB 250
70c/10barebone is offline   Reply With Quote
Old 02-04-2007, 09:37 AM   #5
cooters
changing tailshaft length requires a complete teardown of the tranny to change so it is cheaper to buy a driveshaft then change the shaft.
cooters is offline   Reply With Quote
