Old 02-15-2007, 03:32 PM   #1
swb85
On a budget like Fred Sanford
swb85's Avatar
EVAP canister question
I want to remove the EVAP canister from my truck, it's not hooked up to anything besides the fuel tank, and I'm tired of it just wasting space. My question is about the line on the canister that goes to the gas tank.....what do I do with it? Can I just plug it or is that the only vent for the gas tank?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-21-2007, 03:36 PM   #2
swb85
swb85's Avatar
Re: EVAP canister question
bump......anybody?
Old 02-21-2007, 04:43 PM   #3
grinch4om
dang its hot
grinch4om's Avatar
yes , it is your only vent. drill an eighth inch hole down through the center of the gas cap. plug the line. I did it and it works fine
grinch4om is offline   Reply With Quote
Old 02-22-2007, 12:29 AM   #4
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
You could do that and it will "work," but the canister does serve the purpose of filtering raw gas fumes and recycling them into the carb instead of out into the air.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 02-22-2007, 10:36 AM   #5
swb85
swb85's Avatar
I realize that, but all the lines on my canister have been cut and all emissions equip is long gone so it's not serving any purpose....it's just venting gas fumes into my engine compartment.
Aren't most gas caps vented already? I sure thought they were.
Old 02-22-2007, 06:47 PM   #6
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
on my donor truck i saw some out put the same vent system for the rear axel on that line for the canaster. Thouth that was a smart idea and i plan to do it in my truck that im building.
Srubydo1986 is offline   Reply With Quote
Old 02-22-2007, 09:09 PM   #7
PhilaTruck
PhilaTruck's Avatar
Well, I'd say that if they weren't venting those fumes to the combustion chambers, inside the engine compartment , it's not doing any good anyway. Have fun cleaning out your engine bay.
Subscribe here!
Old 02-23-2007, 08:36 AM   #8
grinch4om
dang its hot
grinch4om's Avatar
no most caps are not vented, when the vapor canisters started showing up the vented caps went away. the fumes are vented to the canister instead of to the air hence, "evaperative emissions control" EPA mandated this in what, 75?
