On a budget like Fred Sanford
EVAP canister question
I want to remove the EVAP canister from my truck, it's not hooked up to anything besides the fuel tank, and I'm tired of it just wasting space. My question is about the line on the canister that goes to the gas tank.....what do I do with it? Can I just plug it or is that the only vent for the gas tank?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 02-21-2007 at 03:35 PM. |
Re: EVAP canister question
bump......anybody?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
dang its hot
yes , it is your only vent. drill an eighth inch hole down through the center of the gas cap. plug the line. I did it and it works fine
Right on the line, baby!
You could do that and it will "work," but the canister does serve the purpose of filtering raw gas fumes and recycling them into the carb instead of out into the air.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
#5 | ||
![]() Quote:
The Crazy Machanic
on my donor truck i saw some out put the same vent system for the rear axel on that line for the canaster. Thouth that was a smart idea and i plan to do it in my truck that im building.
Well, I'd say that if they weren't venting those fumes to the combustion chambers, inside the engine compartment
dang its hot
no most caps are not vented, when the vapor canisters started showing up the vented caps went away. the fumes are vented to the canister instead of to the air hence, "evaperative emissions control" EPA mandated this in what, 75?
