Old 02-23-2007, 02:06 AM   #1
zeitlerusmc
zeitlerusmc's Avatar
<>AnoTheR MoTor QuEstIoN<>
OK so I have a 1968 327 with 1968 327 truck heads, can I put an 1987 throttle body injection system on it I.E intake manifold throttle body, all the censors, and then bolt in a inline electric fuel pump. or is there something special inside the t.b.i motors
zeitlerusmc is offline   Reply With Quote
Old 02-23-2007, 02:27 AM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: <>AnoTheR MoTor QuEstIoN<>
I am no pro on this, but I was tol before that the acual "V" or degree of the sbc V8 was changed between your old motor, and new intake setup. Just my 2 cents, I may be waaaay off on this one.
Oh, and happiness IS a belt fed weapon, ever though I have not had the chance to try one out!
PrerunnerRob is offline   Reply With Quote
Old 02-23-2007, 09:39 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The best thing to do would be to install the TBI onto an OG manifold...you would need a 2-barrell intake though. You would have to fab up an adapter plate.
The MAP sensor and coolant sensor would be no bid deal. Your gonna need the O2 sensor in the exhaust somewhere.
Take some work, but it would work good
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-23-2007, 12:55 PM   #4
glennhuff
If you can get the heads from the 87, then the TBI manifold should bolt on. Of course then your accesories won't bolt to the front of the head. John may have the best idea with a 2BBL manifold. Good luck.
glenn
glennhuff is offline   Reply With Quote
Old 02-23-2007, 12:58 PM   #5
zeitlerusmc
I have the entire 87 motor but I think its locked up! the '68 heads on the 327motor are 64cc truck heads w/ no accesory holes so I would be in the same boat I'am now
Old 02-23-2007, 05:07 PM   #6
Jonboy
Slots go on anything!
If you are wanting to go efi, you could probably put a Holley Pro-jection 2bbl unit on for about what you would spend to adapt the 87 system.
Jonboy is offline   Reply With Quote
Old 02-23-2007, 06:08 PM   #7
zeitlerusmc
how is that holley efi set up is at the minimum 650, I have the entire 87 tbi motor???
Old 02-23-2007, 06:21 PM   #8
project1971
project1971's Avatar
you don't need a 2bbl manifold they make adaptors for the 4 bbl so you can put it on any intake you want too, they are like $40 if i remember correctly.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 02-23-2007, 07:00 PM   #9
Jonboy
If it's locked up, do you suppose everything else will be pristine? If you are going to run the GM TBI, you will want to use the TBI intake (it will make things a lot easier, providing it is not corroded away under the thermostat housing), the distributor, knock sensor, coolant temp sensor (for the ECM, not the gauge), TBI with IAC and TPS, EGR and EGR sensor, and the oil pressure switch (it is usually together with the oil sender, and is above the oil filter. You wil also need a return line to the tank to use the factory TBI. You will also need the VSS and a corresponding speedo head to read the pulses from the VSS. Without a VSS, the system will not go into closed loop, and it will just dump fuel.
You can use the TBI intake by making the 4 center holes oblong to match up with the earlier heads. Only the 4 center holes are at a different angle, starting in '87 with the center bolt valve cover type heads.
Old 02-24-2007, 09:50 AM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Your old heads are by better than the 87's
I would stick with what you got...You have everything you need already !!
That would work too.....it all depends on what you have already. You could always make an adapter too. But if they are only $40......Then again, that $40 could also go into a nice 'switch box' for the "JUICE"
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 02-24-2007, 03:59 PM   #11
zeitlerusmc
dude you were suppose to give me a price on that complete setup man!!!!!
Old 02-24-2007, 04:04 PM   #12
zeitlerusmc
so lets recap the cheapest and easiest way to put this tbi on my 327 would be to use the tbi manifold and oblong the center holes and use all the censors off the tbi and run a ruturn line (which wont be hard since i'm going to do the blazer tank conversion). on a scale of 1-10 how hard is this conversion? am I going to be balls deep on this one?
Old 02-25-2007, 12:12 AM   #13
chevy283
chevy283's Avatar
I did it on my 65 it's not really hard about 7 on the scale. Just remember to hook the vss up.
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 02-25-2007, 12:34 AM   #14
zeitlerusmc
and what does vss stand for again??
Old 02-25-2007, 12:21 PM   #15
Jonboy
Vehicle speed sensor. Before you dive into this, you might want to do a little reading on how the TBI works. Jaguars that run has a couple of really good books on fuel injection swaps, and I think most of the really good FI swap knowledge is on their website. The way it is written makes it very easy to understand. If you can swing it, I would suggest an aftermarket wiring harness. The factory harness will give you a bunch of extra crap you dont need, and it is a pain in the balls to get out of the dash.
Old 02-26-2007, 03:02 AM   #16
zeitlerusmc
already have it out and neatly coiled up I also have the ecu to match sitting by it. I have worked on tbi's before its just been a while. and wondering how common this is. does anyone know where i can have the milling work done to the manifold!?
Old 02-26-2007, 12:11 PM   #17
chevy283
chevy283's Avatar
Just take a drill after it that's what i did worked good. And what ecm number do u have?
65 c10 tore apart
70 c10 305/350th
Old 02-26-2007, 12:19 PM   #18
zeitlerusmc
not sure to be honest with you it all came out of a 1987 suburban! So the drill worked ok? just oblong the holes so they line up and did you get a good seal on your manifold?
Old 02-26-2007, 07:57 PM   #19
chevy283
chevy283's Avatar
It's running good so i guess its good and sealed. lol Look on the ecm there should be a sticker with some nummers like 1227747 on it.
65 c10 tore apart
70 c10 305/350th
Old 03-02-2007, 04:44 PM   #20
zeitlerusmc
hey which distributer did you use chevy283? the hei with the coil in the cap or the tbi dist. with the remote coil, and when you bore those manifold holes what did you do about the heads of the bolts sitting flush?
Old 03-03-2007, 10:40 PM   #21
chevy283
chevy283's Avatar
I use the tbi dist with the remote coil. And here's a good idea on the maniford holes http://www.persh.org/pickup/TBI%20Intake%20Manifold.htm
65 c10 tore apart
70 c10 305/350th
Old 03-03-2007, 10:53 PM   #22
zeitlerusmc
yup I have the site saved on my fav's just wondering if that was what you did too! thanks
Old 03-05-2007, 08:23 PM   #23
chevy283
chevy283's Avatar
No i havn't done anything to mine yet. that's just what im going to do someday.
65 c10 tore apart
70 c10 305/350th
Old 03-05-2007, 10:51 PM   #24
zeitlerusmc
ok well another move in housing has forced me too scrap the t.b.i idea. no room and to time to convert it must get it going quickly. so what do you think the harness, ecu, distr. throttle body, manifold, and most of the censors are worth. Lets say you were going to buy one how much would you pay?
