Old 03-19-2007, 11:32 AM   #1
Tycoon4u
Tooloose
Tycoon4u's Avatar
Question paint reaction please help ???
I painted the top of my cab w/white oil based enamal and found 1 goobered spot on the window post. I sanded it smooth but every time I try to primer the small bare metal spots it softens and blisters the white paint. I've tried both enamal and laquer primer. The white goes on fine over the dry primer but when I spray primer over the bare spots it reacts with the white next to it while wet. Any input would be appreciated.
thanks, Dale
A legend in my own mind!!!
website: http://www.persmedequip.com/
'68 c10 (current project)
http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb
'04 silverado (better halfs)
'07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17
Tycoon4u is offline   Reply With Quote
Old 03-19-2007, 12:03 PM   #2
Tycoon4u
Tooloose
Tycoon4u's Avatar
Re: paint reaction please help ???
anybody? TTT
Old 03-19-2007, 04:33 PM   #3
49studebaker
49studebaker's Avatar
I didn't know anyone used oil based paint on vehicles, but if your primers, etc are compatible I wouldn't know what would cause that. I'll be watching this post 'cuz the answer will be interesting. Good Luck.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-19-2007, 04:51 PM   #4
EZ4U2C
EZ4U2C's Avatar
It could be one of two problems:
1. You may not have the area your reprimering feathered enough. If you leave a hard edge the thinner will cause the paint to lift.
2. The primer solvent my be to strong for the oil base paint.
Let the oil base dry for a good amount. Like a day or two Then resand it and feather it out good. Then when you put your primer back on put it on in a lot of dry coats not real wet. See if this will work
God loved me so much he gave me John 3:16
Buy American and bring our jobs back home.
Trust what you believe in and believe in what you trust.
Don't blame the gun, Blame the person who made you use it!
1970 swb
2002 Harley Davidson Road King Classic
2004 Dodge 4x4
EZ4U2C is offline   Reply With Quote
Old 03-19-2007, 05:03 PM   #5
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: paint reaction please help ???
this is a typical problem I'll tell you how to take care of it , you just need to DRY spray it , what you will need is
#1 one warm day
#2 some laquer primer as you already said you had
#3 sand and clean the area you are having problem with
#4 adjust the trigger stop on your paintgun till it put's out more air than paint ,
#5 hold your paintgun far far away from the area and spray the primer at it with the primer drying as fast as it hit's very faintly ,
#6 you can repeat this till you have a nice cover of dry primer on the area , it can then be painted over , that's how I take care of that ,
if you have some urethane primer you can put a very very very light dry coat of it on last to seal the area ,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-19-2007, 05:33 PM   #6
RustyParts
RustyParts's Avatar
I believe the laquer thinner in the primer is causing the problem, I'm assuming you're using automotive primer and paint and not a rattle can. The solvent is getting under the enamel and causing it to lift.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 03-19-2007, 06:47 PM   #7
meathead95
computer illiterate
meathead95's Avatar
maybe there is some kind of oil contaminate in the metal like a finger print or something try whiping it down with white vinigar and do it again
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 03-24-2007, 11:47 AM   #8
Tycoon4u
Tooloose
Tycoon4u's Avatar
It still did it after several days drying. I think 67 3ontree has it pegged, I'll try that. Should have pics posted soon when I get the cab done.
thanks for the replys.
Old 03-24-2007, 12:30 PM   #9
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
thanks, Dale
The rule is that you can spray enamel over laquer but not laquer over enamel as it will react! You point out that you have tried to use both laquer & enamel primers. The area you are working on is now contaminated and as a result your getting a reaction. First off use a compatible primer, enamel in this case as your finish coat is enamel. You will have to likely sand and prep the piller over and blend it into the roof. Trying to keep the area just confined to where the problem is will not get rid of the various primers that you have used.
Did you purchase your products from a body shop supplier as they are pretty knowledgable people and would only be too glad to help you.
More info. on the type of paint products would be of help to pin point this problem down to it's source. Can you post the product names and who supplied them as this would be a great help to solving this.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 03-24-2007, 12:38 PM   #10
19673ontree
CAN'T FIX NOTHIN
the amount of time has not got anything to do with it , if it drie's for a hundred year's it would still do it , if you try it like I said above it will fix the problem and one more thing that I forgot to mention is that if you push whatever you are working on outside in the sun the primer will dry as fast as it hit's the area !!
let us know how you do , am getting my cab ready to paint right now too ,,
underdash AC
