How does power get to the brake light switch?
i was tracing my wires and it went all the way down under the floor mat..anyone know where these wires go?
sufficiently talented fool
![]() Join Date: Jun 2006
Re: How does power get to the brake light switch?
Power comes from the fusebox to the brakelight switch. It then goes from the switch to the turn signal switch. Then it goes out the firewall near the gas pedal and down to the frame.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
cuz yeah i hooked up the switch but there was no power coming to those wires, other circuits were working so im not sure where the power is not connected
anybody know why this circuit would not draw power when the rest do? possible problem locations??
Is the fuse good?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
there is no fuse
anybody with a diagram?? this would be great also is the turn signal switch the signal switch on the column??
There is a brake light fuse. If you have no power to the switch, you need to check the fuse first.
i bought a whole new painless performance wiring kit, not the stock wiring and fuse box...
I have a Painless harness as well and I didn't have that problem. I would check the fuses as stated above. I'm assuming you tested the wires to be sure if there is power or not. Are you sure your brake switch is good?
72 C10 lwb fleetside -stock 350/350 combo |
brake switch is brand new....the wires that lead to the brake switch have no power to them...in my fuse box there is no fuse labelled break switch, anything else it could be under?
Do the turn signals work? (Probably not). If memory serves, power comes from fuse box, to column, through turn signals and hazard, to brake switch, to brake lights.
signal lights work...
Call painless wiring. They helped me over the phone every time i needed it.
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
#15 |
![]() Join Date: Mar 2003
The wires that go under the floor mat go to the fuel sending unit and the dome lamp.
#16 |
I just checked my fuse box. The brake fuse on mine is labeled as "Stop", so yours should be the same. I would assume Painless labels everything the same, but sometimes you never w/ some companies.
