Old 04-19-2007, 12:24 AM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Any reason not to...
Run RE-6's up front ?
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 04-19-2007, 07:49 AM   #2
Re: Any reason not to...
Wussat?
Old 04-19-2007, 08:07 AM   #3
Orange
Licensed to Thrill!
Orange's Avatar
Yea, RE who?
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 04-19-2007, 10:13 AM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I knew I shoulda posted this in the suspension forum
Sinister
Killer
Old 04-19-2007, 10:37 AM   #5
Orange
Licensed to Thrill!
Orange's Avatar
That was my first thought...but hey, thanks for enlightening the rest of us.
DLB
Old 04-19-2007, 10:59 AM   #6
Joe67
67 is sold
Done
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 04-19-2007, 11:20 AM   #7
DUD2STUD
DUD2STUD's Avatar
In my opinon the RE6 are a little light for your truck I would not run any thing lower than an RE7
DUD2STUD is offline   Reply With Quote
Old 04-19-2007, 02:03 PM   #8
jimmydean
jimmydean's Avatar
Run the RE7. You need the weight and the added lift is nice too. They both lower the same.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-19-2007, 03:57 PM   #9
thekid54
Correct me if I'm wrong, but isn't there only a difference of 100 lbs. between the RE-6 and the RE-7 as far as weight capacity goes? If you're using a stock shock setup up front, you won't be able to use the extra lift capacity of the RE-7, at least I can't. I have RE-6s up front and my shock tops out before the bag reaches max height. The cool thing about the RE-6 is that it's smaller in diameter (obviously), and I didn't have to use cups. I just made a flat circular plate that sits in the lower coil pocket, no clearance issues what so ever.
thekid54 is offline   Reply With Quote
Old 04-19-2007, 06:12 PM   #10
XXL
Seņor Member
XXL's Avatar
What's the basis of your question? As in... why are you asking? Got some RE-6's cheap? or???
XXL is offline   Reply With Quote
Old 04-19-2007, 10:58 PM   #11
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
RE-6
Diameter: 6"
Min height: 3"
Max height: 10"
Max PSI: 180
RE-7
Diameter: 7"
Min height: 3"
Max height: 11"
Max PSI: 180
RE-8
Diameter: 7.75"
Min height: 3"
Max height: 11"
Max PSI: 180
RE-6 Replaces a firestone 255c or contitech 2500# bag. (Front)
RE-7 Replaces a firestone 224c or contitech 2600# bag. (Rear)
RE-8 Replaces a firestone 2800# bag. (Rear duallys)
Yeah, only 100 lbs & one inch smaller tall & wide
No, I just need to know what I'm gonna order
I just thought that if I could do like thekid54 And not use cups & just make a flat circular plate that sits in the lower coil pocket, that It'd solve part of the "nose bleed" problem (front sitting higher than rear)
Thanks Joe67, you
Sinister
Killer
Old 04-19-2007, 11:18 PM   #12
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I didn't use cups. I just made a flat circular plate that sits in the lower coil pocket, no clearance issues what so ever.
Can I get some pics of this, I like this idea
If anyone has pics of the upper being reverse cupped, that'd be great too
I just wanna get as low as I can, without spending much money & I can't afford lower arms or drop spindles (plus I see no reason I can't get as low as I want, by just running no cup on the bottom & if I have to cup the top)
Sinister
Killer
Old 04-20-2007, 03:12 AM   #13
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
CHECK THESE OUT
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 04-20-2007, 08:35 AM   #14
jlaird
jlaird's Avatar
Originally Posted by camaro__thunder View Post
CHECK THESE OUT
Thats what I am in the middle of doing! Slightly different though.
jlaird is offline   Reply With Quote
Old 04-20-2007, 12:37 PM   #15
bedsled71
bedsled71's Avatar
my arms use to be like that but i decided to drag them off. now i have stock arms with 1 inch cups.. i ran the re-7s and then switched to the 6.. i ended up having to run more pressure to get less height.. it says its an inch shorter but i think it was alittle more in my case.. either way i still have plenty if height to get over stuff
bedsled71 is offline   Reply With Quote
Old 04-20-2007, 10:14 PM   #16
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
CHECK THESE OUT
I'm love'n those
Do you think that they'd hold water ?
Sinister
Killer
