Old 04-23-2007, 02:11 PM   #1
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Exclamation 66 3/4 ton 4wd suspension/brakes question
My buddy has a '66 3/4 ton 4wd longbed. He is having problems with the brakes. The manual said that he needs a special tool to remove the rear drum assembly because the hubs are integrated. The manual calls for Chevy removal tool J-2222. He also isn't sure if he has 5,200 lb. or 7,200 lb. axles.
Does anyone know if he needs this tool, where to get it or which axles he has? Any advice? before he tears it apart?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-24-2007, 01:16 AM   #2
Pistonman
Re: 66 3/4 ton 4wd suspension/brakes question
My 66 GMC has a Dana 60. I use an impact screwdriver to take 2 screws out that retain the drum,then back the shoes off and remove the drum.
What axle does it have?
Pistonman is offline   Reply With Quote
Old 04-24-2007, 12:15 PM   #3
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
If the hub and drum are integral, they may be taking about the hub socket to disassemble the wheel bearings.
Jason
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 04-26-2007, 12:33 AM   #4
Pistonman
He may need a spindle nut socket, as mentioned above, available at parts stores or Snap-on etc.
