Old 05-30-2007, 03:12 AM   #1
knightlife
Dark Heart Motorsports
knightlife's Avatar
any suggestions?
Im looking to replace my stock granny low 4-spd with something quite a bit more performance oriented...
I want a 5 speed with the 5th gear at least 1.00 to .80...but havent had any luck, I'd like it to be a direct swap if possible. any ideas or suggestions? it seems as tho charleston isn't exactly performance oriented :/ sad it is really...so much potential on I-26
thank you in advance!
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 05-30-2007, 03:59 AM   #2
DURRTY
USMC
DURRTY's Avatar
Re: any suggestions?
Take a look at a NV4500 the OD(5th) is .75 and they are tough as woodpecker lips. Not a direct bolt in though they do sell the adapters.
Semper Fi
DURRTY is offline   Reply With Quote
Old 05-30-2007, 07:45 AM   #3
greg0380
I went from the SM465 to a NV3500. IT was a fairly simple job, the only thing I had to deal with was make a new hydraulic line for the clutch. The slave cylinder for the NV3500 is on the passengers side, plus the speedo pickup is magnetic (but I already had an electronic speedo).
If you go this route, read around. There are different versions of the NV3500, the later ones are supposed to be better. However mine came out of an 89 Cheyenne and has well over 200,000 miles on it. I put it in with 189000 and have never done anything to it.
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305
5 speed, 3.42 rear
2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L
1999 BMW 528i
greg0380 is offline   Reply With Quote
Old 05-30-2007, 11:35 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Richmond 4+1 has a 1:1 ration in 5th and will bolt in place of the current trans. http://www.richmondgear.com/01fivespeed.html It also isn't cheap unless you find a used one, but comparable with the current offerings like the TKO 5 speeds.
http://www.keislerauto.com/gm/transm...t_rod_5spd.asp
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-30-2007, 03:05 PM   #5
knightlife
knightlife's Avatar
that 5 spd road racer from richmond *shivers* I like what it does to me...
the nv3500 has the exact gearing I want tho...*pulls hair out* decisions decisions
thanks yall for the input...it helped tremendously!
Old 05-30-2007, 05:45 PM   #6
Captkaos
Captkaos's Avatar
If you get the "NV3500", make sure you get it out of a full-size pickup which is actually is a NV3550. not a NV3500 which is the S-series. The NV3550 has beefier components.
If you plan to really abuse it, go with the TKO or Richmond.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-30-2007, 07:01 PM   #7
knightlife
knightlife's Avatar
abuse naw....only 867 hp worth of balls being slammed to it
Old 05-30-2007, 08:54 PM   #8
Captkaos
Captkaos's Avatar
Anything over about 400lb/ft will destroy a NV3550 if it is abused. They are a light duty trans.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-30-2007, 09:48 PM   #9
knightlife
knightlife's Avatar
damn...so no supercharging the 383 and no nitrous? *starts crying like a drunk midget*
Old 05-30-2007, 10:26 PM   #10
Pyrotechnic
Pyrotechnic's Avatar
T56 6 speed ?
I think they will hold around 400HP just fine. Even then, there are strengthened versions that can be had. Remember, this is the same trans that is used in the Dodge Viper.
Pyrotechnic is offline   Reply With Quote
