Old 06-26-2007, 04:28 PM   #1
1983shorty
1983shorty's Avatar
brake light
the brake light is on on my 83 . every once in awhile the pedal goes down a little farther than normal and the brake light comes on . stays on until the next time the pedal goes down farther than normal , then it goes out. new pads and rotors . brakes work " good " . never have worked "great" since i had the truck. i suspect the master cyl may have an internal seal going bad ? what do you guys think ?
1983shorty is offline   Reply With Quote
Old 06-26-2007, 06:01 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: brake light
If your not loosing fluid, it is probably the MC.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 06-26-2007, 07:14 PM   #3
1983shorty
1983shorty's Avatar
Re: brake light
nope , not losing a drop of fluid. i am pretty sure its the MC i guess i just want a little validation before i spends the $$$
Old 06-26-2007, 07:40 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: brake light
I have the same problem with my 83. Happens only then I hit the brakes really hard. Truck stops on a dime!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-26-2007, 10:46 PM   #5
Yankeelights
Yankeelights's Avatar
Re: brake light
Yup, sounds like an internal seal in the master.
Yankeelights is offline   Reply With Quote
Old 06-26-2007, 11:28 PM   #6
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: brake light
MC it sounds like to me
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 06-27-2007, 02:12 AM   #7
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: brake light
Definately a master cylinder. Mine did the same thing. Only problem is my brake light never went out.
Front to back, my entire brake system is brand new. Still the light on the dash wouldn't go out.
I took out the bulb
xtreme80 is offline   Reply With Quote
Old 06-27-2007, 05:04 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: brake light
I took out the bulb
You can adjust the tab that holds the plunger to make it not stay on. Just screw it up onto the bracket.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-27-2007, 07:52 PM   #9
xtreme80
xtreme80's Avatar
Re: brake light
Sweet! Didn't know that! I'll give it a try tonight and let you know.
