Re: 18,19,20's wheel size.
Nothing came up only this thread
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
The 5" BS for the front is good. It's the rear BS I was explaining & the effects on the overall 'look' of the wheel/tire combo on the truck.
#3 | |
I think I will be running som Adaptors but I am just not to sure what size maybe 1.5"?? the front is going to be 5.0" bs w/ an 8" rim ther rear is going to be an 8.5" rim with a 5.4" bs either a a 1" or 1.5" Adaptor should work?? I dond want the tires to set in to far.
#4 | |
I would go w/4" BS on the rear. So.... if you use the 5.4"BS wheels, you'll want the 1.5" adapter. What size tires again?
245-45-R18 in the front and 275-40-R20 in the rear. When I pulled some measurments on my truck I came up with a 1" to 1.5" adaptorin the rear. It was hard to be exact without wheels to test fit
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 06-28-2007 at 09:05 PM. |
#6 | |
See how a known wheel fits & get BS measurements. Then add or subtract the difference of the 'new' wheels BS & see how far in or out you need to go.
Chevyman, Those are the FOOSE Nitrous II's. The best price I found was from a place called TiresDelivered.com out of Ohio. The wheels were 2500 and I paid 600 for the tires. Now, these prices include the shipping to my door, mounting, balancing and new lug nuts. The color on the valve cover is a 2004 GM Sunburst Orange. I'll get the OEM code and post it for you.
#8 | |
