#51 |
Re: 18,19,20's wheel size.
Chevyman, Those are the FOOSE Nitrous II's. The best price I found was from a place called TiresDelivered.com out of Ohio. The wheels were 2500 and I paid 600 for the tires. Now, these prices include the shipping to my door, mounting, balancing and new lug nuts. The color on the valve cover is a 2004 GM Sunburst Orange. I'll get the OEM code and post it for you.
#52 | |
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
#53 |
Tot Roddin'
Hey c10ss69, do you have any more pictures of your truck? Would love to see more of it!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#54 |
I started a thread the other day called "My Project". There are some pics of my truck there. I plan to add to them as I can and as I get more done.
#55 |
Lets see some new pics
#56 |
fronts 18x8 with 5 1/4 backspace with 245/40/18 rear 20x9.5 with 5 3/4 backspace with 265/35/20
#57 |
Nice looking setup Skunkwerx I suspect my setup to look simular but in a lwb. Cant cut my bed down need the 8' to hall a sportster I've been looking at
#58 | |
#59 |
A guy with a truck
Man, you change wheels like underwear... Looks good. What's next?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#60 |
yea i get that alot,the 1st pic 17" 2nd 20" 3rd15"factory ralleys also have a different set of 20" that i might do next?
#61 |
its just $$$$$
#62 |
Sayre, west on I-40
#63 |
#64 |
on the front made a plate that bolts to the crossmember for the top of the bag to mount and made a 1" cup for the bottom.on the back put in a bolt in c-notch and extended the pan bar across to the trailling arm,bolted the bag on the bottom in place of the coil spring to the trailing arm,at the top i made a cup 1 1/2" thick with a bolt weilded to the center so it would bolt where the spring was on top."simple"
#65 |
forgot to say i have 2" lowering blocks on the back also.
