Re: 700r4 and a 205
Advanced Adapters (AA) makes an output shaft that makes your 700r4 look like the back of a th350 out of a 4x4. The bolt pattern on the case is the same, you just need an output shaft to mate right with your adapter. Buy the output shaft from summit (they are cheaper than from AA), take it and your case to a tranny guy that knows what he is doing, have him rebuild it while he has it apart.
The 700r4 is almost 2 inches longer than the th350. You can move the transfer case back 2 inches and have work done on both driveshafts or move the engine forward the amount required. After reading about other's swaps, I think I'll move the engine forward as there is more than enough room if your V8 is in the factory 4x4 position. My 700r4 has been on the shop floor for a couple of years waiting for me to get motivated, and come up with some cash.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#2 | |
Re: 700r4 and a 205
At little word of advice... while you have it all out, change the seals in the coupler that goes between the tranny and the t-case. I didn't change mine, and now my t-case is full of ATF. Another project that could have been avoided by a few minutes worth of work while I already had it out!
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
#3 | |
Re: 700r4 and a 205
