Old 07-06-2007, 02:14 PM   #1
Joe T
black rtv or red?
i picked this up to use because i am putting in a new intake manifold this weekend:
http://www.jamestowndistributors.com...pid=8625&PTECH
i was reading previous posts and most people say to use the black rtv. is this what they are talking about:
http://www.jamestowndistributors.com...ilicone+Gasket
i went with the red because it is for high temp. why do most of you guys recommend the black?
Joe T is offline   Reply With Quote
Old 07-06-2007, 02:21 PM   #2
Myself
Re: black rtv or red?
I personally have quit using RTV all together. I now use only Mega Grey Import gasket maker or Mega Black gasket maker. I have had much better results with these and they don't stink like RTV.
Myself is offline   Reply With Quote
Old 07-06-2007, 02:31 PM   #3
Joe T
is this what you use?
http://www.itwconsumer.com/catalog.aspx?prodID=2
where do you get it? and can i put that on the bolts, or should i use a teflon sealent?
Old 07-06-2007, 02:47 PM   #4
jamis
F.A.S.T. president
jamis's Avatar
The prematex ultra series has been the best I've found to date. Its alot stickier and more duarble then the standard RTV. It comes in black and high temp copper.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 07-06-2007, 04:13 PM   #5
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 07-06-2007, 04:36 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
For engine assembly, I have shifted over to the NAPA "Right Stuff" adhesive. It is an outstnding product, in my book.
Old 07-06-2007, 05:36 PM   #7
kwmech
Permatex ultra grey or black--------------period
Old 07-06-2007, 05:53 PM   #8
Myself
Yes that's the stuff, the Permatex Ultra is of the same type, it's just a diferent brand. It works great also, just more expensive.
Old 07-06-2007, 06:26 PM   #9
kelsfine69
18 Till I Die
kelsfine69's Avatar
Clean the intake bolts really well and use a Teflon sealer like you use one water pump bolts. Then run a bead of black sealer on the front and back of the block and toss the rubber ones that come with the set. Add the intake gaskets nice and clean and use no sealer on these. Drop on intake and torque to spec. Once you drop it on there's no removing or you will have to clean the black silicone off and start over.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 07-06-2007, 06:32 PM   #10
msgross
msgross's Avatar
silicone the bolts that go near the water chambers too,
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-06-2007, 08:41 PM   #11
Joe T
i was reading this post:
http://67-72chevytrucks.com/vboard/a.../t-225820.html
and he had put the sealer on the gasket. the instructions that came with the manifold said to do this as well.
Old 07-07-2007, 12:28 AM   #12
68speedalert
Semi-Senior Member
68speedalert's Avatar
Again...
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 07-07-2007, 01:28 AM   #13
cameeks
Long Fleet Club
cameeks's Avatar
The high temp is mainly for the exhaust. Your intake should never see those kinds of temps.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 07-07-2007, 10:38 AM   #14
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Watch out for RTV...room temperature vulcanizing...products. Some are for automotive use. The problem is that as they cure, they can corrode the surfaces on which you put them, i.e., using them around a windshield and letting it contact the metal of the body. This may not affect any of the engine work, but the manufacturers specify what you should be using for a given task.
Member Nr. 2770
Old 07-07-2007, 11:00 AM   #15
truckdude239
truckdude239's Avatar
black rtv the high temp is what i use
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-07-2007, 12:16 PM   #16
sick69
sick69's Avatar
"rite stuff"
http://www.partsamerica.com/ProductD...egoryCode=2132
It ussually runs about 11-13 a can. I have found it at advance auto and napas. I quit using silicone rtv when I found out about this stuff.
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 07-07-2007, 02:06 PM   #17
kelsfine69
18 Till I Die
kelsfine69's Avatar
You shouldn't have to give the gaskets any coating. If you get the Fel-pro ones they are designed so seal with no silicone.,also it makes the gaskets tend to "slide out" when you torque them. Also i never use silicone on the bolts. GM has always used a Teflon sealer like the plumbers white stuff to seal the bolt threads.
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
