Old 07-14-2007, 10:52 PM   #1
SactoJim
SactoJim's Avatar
Factory Tack Problem
So I was installing a diff fuel guage since I wiped some of white graphics off the old one when I was cleaning it and when I put it all back together the tach wasn't working correctly, (%$#@)! Worked fine before, but now it sits at zero at idle (approx 500 rpm) and I'm guessing it lags about 500 rpms behind as I rev it up. I messed with the adjustment at the back and it will not correct it, though it does change how fast the needle moves across the gauge.
I did refinish the needles when it was apart and then blew the cluster out with some compressed air......I'm totally stumped and pissed too cuz it screwed up my planned progress today.
Just for more info, it is hooked up to my MSD tach output, but like I said before, it was working.
Any ideas?
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 07-15-2007, 01:05 AM   #2
byrd
Union Electrician
byrd's Avatar
Re: Factory Tack Problem
What about the ground screw near where the fuel gauge is, are you sure it is tight? I would check for ggrounding issues if it were me...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-15-2007, 01:18 AM   #3
SactoJim
SactoJim's Avatar
Thanks Randy....
Ground is definately fine. It works fine as far as revving the engine up and the tach needle progressing through it's arc.....like I said before, it just seems like its behind 500 rpm +/-.
I can't figure out what I did while I had it apart!!
- supercharged 383
- 4 wheel discs
My Build Thread
Old 07-24-2007, 07:33 PM   #4
SactoJim
SactoJim's Avatar
ttt
Just got back from my honeymoom......I'm broke!....and can't afford a new tach.....nor can I spell it (tack?)
Thought I'd bring this back to the front and try to get the attention of all the tack "experts".......anybody?
- supercharged 383
- 4 wheel discs
My Build Thread
Old 07-24-2007, 09:49 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Sits at zero at idle? I guess I would take it out and hook it up directly and see if it then reads right. If so,track down the bad connection,if not find out what dirt etc.got blown into the delicate mechanism.I'd study it closely and shoot some air at key locations. I don't remember mine having an adjustment in the back,you sure it's factory?-Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
