#26 |
I'm a poor spectator
Re: Daily Driver
I alternate between my 04 Mazda B3000 (gas saver) and the k5. I don't consider one more reliable than the other, i'd drive either one of them anywhere and I wouldn't have a single problem (the Mazda does have AC though
![]() ![]() The green one is Critter's, another member. ![]() Ah, what the hell, here's the mazda too. ![]() And one more... ![]()
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#27 |
Re: Daily Driver
i drive my '69 every day, round 300 miles a week. had never let me down as long as im easy on her. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
#28 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Daily Driver
Here is mine. I use her as my daily driver from mid April till late Sept. or early Oct.. To me our winters are too harsh to use these trucks as dd's here but there are a few diehards that in the city that use them all year around.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#29 |
upgrading to an older model
Re: Daily Driver
Mine is gonna be a daily... I bought it to replace my current truck...a 2005 F-150 (it was part of a truck/boat package). I definetly think It'll be an upgrade.
As far as that snow stuff...I'm a teacher if its snowing, I'm sleeping in. |
#30 |
Old School, New Style
Re: Daily Driver
The first year I bought my Sub I drove it all winter but I confess I can't keep doing that. The Sub, Jimmy and Impala all rest in storage over the winter. The salt is so bad here in ohio that my wifes 02 Venture's rockers are already going to pot. Winter just sucks here.
Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
#31 |
Old member
Re: Daily Driver
Let's see daily driver huh! I have owned the 71 since 1986 it had 80,000 miles on it when I bought it. It had only power steering & brakes. Now with the 305 HO TPI motor in it with 280,000 miles on it and still running.( first motor I ever built) I have added to this since then.
I'm having it repainted for my son to have it. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
