#26 |
![]() Join Date: Nov 2004
Re: 4 core radiator and thermostat...
Funny you should mention them, a guy at work mentioned them too...
I might mock up my cooler and drive over there. I think I've got most everything figured out ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#27 |
![]() Join Date: Oct 2005
I just added one to my truck today. Not to bad of a job to do. I got it from advanced auto. I also have a problem with my truck running the temp up while I'm running the A/C. I have a 4 core radiator as well and cant seem to keep it cool when I'm in stop and go traffic. Once I get it out on the intersate as long as the traffic is flowing it does seem to run at about 185. I am thinking of going with a 160 degree thermo in mine to see if it helps me some.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
#28 | |
What fan and shroud set up do you have on your truck? Sounds like an airflow problem at slow speeds. |
#29 |
stock fan,no clutch, stock shroud. I noticed this situation after adding the heater control valve back into the system. I think I have it connected wrong.not sure if it matters though.
#30 |
I put the cooler on yesterday, unfortunately, I won't be able to get to the lines for a week or two, I'm leaving for NY in a couple days. You can't see it at all under the truck. It was a pain to get it level because of the low hump in the middle of the crossmember. I put it as far to the driverside as I could to leave room for the lines. They'll run between the crossmember and the radiator...everything is right there! This is the one that has the two inlet/outlet on the same side.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-14-2007 at 11:09 AM. |
#31 |
Before you added it, some heat was probably being let off by running through the heater core, but now that you have a valve that closes it, nothing can run thought it.
#32 |
Heater core= mini radiator
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
