Old 09-07-2007, 01:19 AM   #5
draggin86
draggin86's Avatar
Re: Weight of Cab
I have swapped cabs a few times here is how i did it... i had the rearend out before so this made it easier.. anyways so i jacked up the truck really high used some 7 ton jackstands almost all the way up i put the stands under the pinch weld of the cab then unblot the body mounts lower the frame down then basically pulled the frame out from under cab..
draggin86 is offline   Reply With Quote
