#201 |
Next project: 1970 K10
Re: Glock's official "Project 68" build thread
No need for one..... I kinda sometimes smoke, mostly when I am working in the shop, but I never smoke in the house or any of my vehicles.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#202 |
hmm...you payin attention 68 ss?
R.I.P. Killer 71 10/26/07 |
#203 |
If I had more time (which I do) and really wanted to do it (which I don't), I would make build-outs (like I did for the gauges) for the A/C vents, HVAC control, and stereo. But that is a lot of work, and I don't want to keep pushing this thing any farther behind.
This is the third attempt at doing something different to the dash. It started with cutting out the center and welding in a smooth piece. I didn't like the end result, and about a year later I cut it out. I then welded in a piece that made the dash smooth all the way across, and would use the stock gauges and glove box. It looked alright, but I still wanted something different. So this is the end result, and I really like this one.
#204 |
Well, the dash is starting to take shape. I got the billet A/C control panel yesterday, so I laid out the center section pieces on some template paper and got everything cut out. I left room at the bottom for the two pop-out cup holders that will come later on down the road.
The glove box door is basically done as well. I just need to work a little more on figuring out the opening size and shape, get the hinge tweaked, and figure out bracing for the back side of the dash. The bracing will not only stabilize everything, but provide the means for attaching the hinge, the latch, and the eventual glove box compartment that will be made after the A/C is installed. Also had a little help last night, even though Momma thought he was sound asleep in his spider web!
#205 |
A couple more of the dash, and the finished glove box door.
Something else I finally got done was to drill and tap the back side of the gauge bezel so that it can now be attached to the dash. No more fear of it falling out! I know, it probably should be safely stored in it's box, but it just looks too darn cool in the dash to have it hiding out in it's box!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-07-2007 at 09:41 AM. |
#206 |
Next up is figuring out where to mount the headlight switch, the wiper switch and the ignition. I have several ideas shown below, but I just can't make up my mind.
I can either mount the lights and the wipers side-by-side to the left of the column, low on the dash, with the ignition in an equal location to the right of the column. Or I can put the lights on the left side of the gauges, the wipers on the right side, and the ignition down low (the purple circle in the pic below). That leaves me with the decision of having the switches just above center of the gauges (green), inline with them (blue), just below center (yellow), or directly under the outermost gauges (red). ![]() At this point, I'm leaning towards under the outer gauges (red circles), with the ignition in the spot shown (purple). That would help fill the big open area on either side of the column. Thoughts, ideas, suggestions????
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-07-2007 at 10:19 AM. |
#207 |
Farm Truck
![]() Join Date: Aug 2006
Cig Lighter for Cell Phone......Too
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
#208 |
Dang, how could I forget that?!?! OK, so maybe the ignition on the left of the column, and the 12v outlet on the right....... That would balance everything out nicely. Or, I could mount the 12v outlet inside the glove box, hidden and out of the way.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-07-2007 at 10:51 AM. |
#209 |
Looking great Bob!
You do nice work! I think you may have inspired me to put some custom gauges in my little green CST...
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#210 |
I think a nice set of gauges would look great in that truck!
#211 |
![]() Join Date: Aug 2005
That dash is looking soooooo classy! What are you doing for seats? If you'll have buckets and a console you could put the cig lighter in the console. Maybe even the ign sw? That would keep your dash clean.
I was thinking on my 61 I might try to put the wiper and lights switches on the column. There are aftermarket switches available that are made to go on the turn signal, tilt, or shift levers. Otherwise I like the red position or halfway between red and yellow, even with the outside of the outer gauges. Just to make your decision that much more complicated ![]() |
#212 |
Farm Truck
Could use a colum out of a Later model with all that on it to conserve space.
#213 |
Thanks for the help Mike!!!! But I do agree, the more I stare at it, the more I am leaning on the lower corners as the best spot.
I haven't really made up my mind on the seat yet. Since I plan on cruising the kiddos around with me, I will definitely have a bench of some sort, either the original, or a 60/40, or a 40/20/40. I actually like the original, it had been rebuilt just before I bought the truck so the foam is new, but I would have a new cover made for it. Or, I would like to find a late 80's bench, or a late 80's/early 90's 60/40 split bench.
#214 |
that dash is coming around!! Just keep in mind for the ignition switch that the keys\keychain will swing and scratch up the paint. you could always use a single key? Lower corners would be good!
#215 | |
So a new set of matched ignition/door locks will be in order. Also, I had thought about doing clear film on the lower part of the truck when done. I have to travel 3 miles of gravel road round trip to see pavement, so I had the idea of doing a little piece of the clear film around the ignition area to. Headlight and wiper switches: ![]() Here is what I did to the ignition. You can't see it in the second pic, but the spacer sits flat on the cardboard.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-07-2007 at 01:45 PM. |
#216 |
Hmmm, yeah, I think I like the new look better that what I had going on before!
#217 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Try this out???? Mount em on a pannel here it might be awkward at 1st but I am sure it will clean up the dash ...Mount the pannel horizontal to the dash am I makein sence or
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#218 |
Hmm, that does give me an idea! I still need to weld in the piece under the dash to fill in were I cut the center out. I could make a piece that gently curves down then back up and mount them something like:
Lights - Ignition - Wipers Thanks! I kinda like that!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-07-2007 at 08:55 PM. |
#219 |
Is the center section going to have any contours like the bezel or is it staying flat?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#220 |
Mike, if you are talking about where it radio and all that is, it will stay flat. Actually, the my original intentions were to have everything flat to the dash, but since I couldn't see the upper numbers on the speedo when it was flat to the dash, that's what led me to make the angled build-out for the gauges.
#221 |
I like the angled parts since it keeps the dash from looking like a large piece of sheetmetal. I know that your far from done on it but it's looking good.
#222 |
I had though about making build-outs for the radio and A/C controller, and making build-outs for the two vents that angle them slightly to each side. It's not totally out of the question yet, but it's a lot of work to make those.
I've been thinking of different options for the glove box door too. I'm looking at other doors that might have a unique shape, like a 61 Corvair Monza door. corn also posted a pic in another thread I started of an Impala door that is steel, but has "grooves" in it like ball milled grooves in aluminum. I think I could make a similar door from a piece of billet and do the ball milled grooves. Laying in bed last night, I though "why couldn't I make the door thicker at the bottom than the top? That would fit right in with the angled gauges..... I have a mill, so I'm not sure why I couldn't at least try it.
#223 |
![]() Join Date: Oct 2006
Why not use a later model column with the ignition switch,wiper controls in the column? That would kill two birds with one stone! Just a thought........
-Lance BTW this is looking GREAT!
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#224 |
I have thought about it, but a couple of things keep coming back to me:
- I like the simplicity of the van column, and I will be using billet handles/knobs on it, so I would like to keep those as clean as possible. - The light and wiper switches are real nice billet pieces from Ron Francis, and have a color matching band around them. I think they would look pretty cool sticking out of the dash. Right now it's just a matter of where they will stick out! Thanks for the suggestion thought! I'm always open for new ideas for this truck.
#225 |
How bout installing "The Clapper"
