Old 09-23-2007, 02:36 PM   #1
Sweet 85 C10
OG
Sweet 85 C10's Avatar
Re: Street Rod Sugar Daddy (Dino63's 78 C-10)
Nice! Only reason im asking is because alot of people ive seen only installed the 4 link and canti setup. I want to do it the right way pan hard bars are cool but im impressed with the Watts link.
Originally Posted by RunninLo View Post
Since KP's 4link in this kit is of a "parallel" design and the cantilever is as well you will still need something to restrict side to side axle movement. A pan hard would work but would pull the axle off center as it swung through it's arc as ride height changed.This can be minimized by using the max length bar that will fit.
The Watts is the superior but slightly more expensive route do to it's more complex design. It will allow full range of motion with minimal, if any, side to side movement.
Sweet 85 C10 is offline   Reply With Quote
Old 09-23-2007, 03:17 PM   #2
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I try to use watts exclusively now since doing my first on our 92 Tow pig. It is a frame laying, 2.5" stock floor body dropped chevy crew cab dually. I Originally built it with a panhard bar but it was getting into the dually fenders.
A lot of guys will tell you towing and air don't mix but this thing is overbuilt and a triangulated 4 link wasn't an option. Watts were starting to pop up in the scene and so I built my own after talking to a few guys who were using them. Truck has about 25k miles on it since install and other than road grime still looked pretty new. We use it primarily to tow another extra-cab dually, a 64 impala, or 55 pro-street to shows.
here's a small pic:
RunninLo is offline   Reply With Quote
