1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Header Gasket advice - Which ones are better?
I'm going to be putting in the new exhaust this weekend but i cant seem to find a good gasket. I need thicker ones .... THAT DONT LEAK! I'm tired of damn header gaskets that blow out. So i bought some locking header bolts and now all i need to know is what you guys think i should use for gaskets.
They need to be thicker .... please if you have some time to point me in the right direction i would be thankfull. Gaskets are for 350 sbc. If you have some pics that would kick a$$ ... thank you -Hart
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project Last edited by JHART; 10-04-2007 at 08:08 PM. |
Re: Header Gasket advice - Which ones are better?
I use copper.....they are thin.....but they won't blow out......and they are re-usable if you have to remove headers for some reason.
A..........
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
1972 Shorty Owner
I was looking at those also but i think those will be too thin for my set.
This is killin me .... lol
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
Active Member
I used Percy's Carbon gaskets, they seem to work just fine
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
1972 Shorty Owner
Do you know about how thick they are?
Just go buy a set of exhaust manifold gaskets & your troubles will be over. Thats all Ive ever had any luck with on small blocks...
![]() Join Date: Nov 2006
copper is best you can get
I BELIEVE IN JOHN 3:16 |
Chevy nut
I would go with copper. I have the regular exhaust manifold gaskets on my Firebird...and they are blown out already. Why do you need think ones? Did you have some mill work done to the outsides of the heads?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
![]() Join Date: Jan 2007
I like these the best.. always seal tight and last.
http://www.holley.com/99150AFLT.asp |
1972 Shorty Owner
No mill work. The headers are round port and they stand out a little bit from the flange so i think thicker ones will be better. But if you guys think otherwise?
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project Last edited by JHART; 10-04-2007 at 09:32 PM. |
![]() Join Date: Jul 2006
I've heard copper is good but I haven't tried them yet.
If you are going to use regular gaskets try one of two things. Either soaking them in water and or vegitable oil first and then put them on. They'll swell up and adhear to your ports/header primary tubes. |
there supposed to stand out, its how they get a sealing surface. do you go back and retighten them several times after you get them hot ?
1972 Shorty Owner
Well with the old ones yes. But these are the new ones i am putting on that i want to go thicker with.
I think i am just going to go with some basic gaskets and the the lock nuts and see what happens. Keep the advice coming though so more people can read this and hopefully get something out of it. I will post pics this weekend with some sound clips of the open headers before i put the mufflers on ![]()
try these
http://www.holley.com/99150FLT.asp |
#15 |
it took a while,but I am a believer in copper now.
#16 |
![]() Join Date: Feb 2001
Cut the flanges of the headers and get a set of mainfold gaskets and be done with it.
#17 |
#18 | |
I agree with CORN & Mudder on this. Cut the flange between each port. (But, not thru any mounting holes!) And get you some cheap A$$ manifold gaskets. Take a quick run and tighten again. Works great!! Prolly due to less combined flex - each tube can flex individually. - Dave Like this...
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
