Old 05-17-2002, 08:56 AM   #1
72BACK2NU
Post manual steering adjustment
I have quite a bit of free play in my steering. I guess they are adjustable. Is that something I can do with no shop & basic tools?
72 GMC C1500 2WD LWB
As for me and my house, we shall serve the Lord.
White City, OR
Looking for Oregon 72 GMC donor w/PS & column-shift auto
72BACK2NU is offline   Reply With Quote
Old 05-17-2002, 09:29 AM   #2
68 Suburban
68 Suburban's Avatar
Post
On the top of the gearbox there is a 5/8's locking nut with a little shaft coming threw it with a slot for a flathead screw drive. You can loosen the locking nut and tighten the shaft clock wise. Make sure the wheels are straight when you do this. I would only go a half turn at a time. If it is too tight, the steering wheel will not return properly after you make a turn. I have been told never to adjust so that the little shaft is lower than the locking nut. Oh, and make sure you tighten the locking nut back up
Check out other members trucks
1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place)
1968 50th Anniversary C-20 Pickup CST, Sold to Fine69
1969 SS Camaro Conv't
1960 Lakewood Travel Trailer
1963 Ford Falcon Wagon, Still For Sale
Phoenix, AZ.
Click Here for Parts and Venicles I have Available
THINGS I AM LOOKING FOR:
67-68 SUBURBAN TRIM. $$$$ Reward
for finding the 3rd door trim piece
and the small piece that goes on
the 1/4 panel right behind the
3rd door.
Click Here to see the two pieces I need.
[This message has been edited by 68 Suburban (edited May 17, 2002).]
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-17-2002, 10:06 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Some of them have an allen bolt instead of the slot.
A slightly better way to do it, is to have an assistant (wife, neighbor kid) turn the wheel back and forth in the free play area while you are tightening it.
You will most likely not get all the slop out of it. HTe manual gear box is a known sloppy item.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
