Old 12-20-2007, 01:29 PM   #1
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
estimated hp of 400 small block
just wondering how much horse power you guys think i have, its a 400 smallblock, not a bored 350, with 2 1/2 inch headers 4 barrel eldebrock carb, slightly raised holly intake, flex fan blades
http://www.nastyz28.com/sbchevy/sblock.php
Years Casting CID Low High Main
Power Power
1970-73 3951511 400 255 265 4
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 12-20-2007, 01:43 PM   #2
Billla
Billla's Avatar
Re: estimated hp of 400 small block
Compression? Cam? Heads? Valve sizes? Rocker ratio?
Billla is offline   Reply With Quote
Old 12-20-2007, 04:32 PM   #3
Hillbilly Deluxe 65
compression is 9: 1 and the rest is stock for the 6.6 litre out of a 72 caprice classic
Old 12-20-2007, 04:45 PM   #4
Billla
Billla's Avatar
Making me do your homework, huh?
That engine was rated at 170 HP in '72 with an 8.5 CR - it was rebuilt and upgraded?
I'd give it the benefit of CID and say 260 - 275HP at the flywheel max.
Old 12-20-2007, 05:12 PM   #5
Hillbilly Deluxe 65
caprice classic article claims they have 260 max stock at the flywheel, and im sorry i forgot to mention this is the turbo edition 4 bolt main, and thanks, i have done much research on this motor cause it was in the truck when i bought it and this bad boy will scream, with the B&M ratchet shifter, i mean ill do burnouts with no brake just floring it for a good 50 ft
Old 12-20-2007, 05:32 PM   #6
Billla
Billla's Avatar
A 1972 Caprice "Turbo Edition"?
Old 12-20-2007, 05:49 PM   #7
EyeH8the24
EyeH8the24's Avatar
turbo fire motor maybe ?
EyeH8the24 is offline   Reply With Quote
Old 12-20-2007, 05:57 PM   #8
Billla
Billla's Avatar
This is not a unique attribute of a truck with 70/30 weight distribution
Old 12-20-2007, 06:15 PM   #9
leftcoast66
leftcoast66's Avatar
leftcoast66 is offline   Reply With Quote
Old 12-20-2007, 06:27 PM   #10
sick69
sick69's Avatar
Just out of criousity,,,,,,,,,what is the tire, wheel and gear ratio?
A short/skinny wheel and tire combo could be lit up with a v8 only running on 7.
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-21-2007, 03:38 AM   #11
Hillbilly Deluxe 65
turbo fire yes, and i know the weight ratio is way higher in the front, i mean with 3:73 rear end gears and and 265/70R15 this truck does alright
