Old 02-07-2008, 01:22 AM   #26
chev74
Addicted to Chevy
chev74's Avatar
Re: Just ordered mine- who else has them?
Originally Posted by boxrodz View Post
I don't believe their light dimmer kit will work with your LEDs. It looks like a rheostat (or potentiometer) that is spec'ed for their vacuum fluorescent displays. What your are after is a pulse width modulator (PWM) which, by the way, uses a potentiometer to 'adjust the brightless' of the LEDs. Basically, a PWM varies the duty cycle of the LEDs so that the LEDs are actually blinking slow enough where they look dimmer without actually seeing them blink. You can get it a PWM kit for under $10. Search for 'PWM DC Motor Speed Control LED Driver'.
AWESOME MAN!!! geez you guys are helpful sometimes
chev74 is offline   Reply With Quote
Old 02-07-2008, 01:27 PM   #27
andresco50
andresco50's Avatar
Awesmoe guys but I prefer the oem look
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 02-07-2008, 02:58 PM   #28
chev74
Addicted to Chevy
chev74's Avatar
i liked the original look for a long time, and still do. but i just had the chance to get the tach cluster, and wanted to update some other stuff for looks.
but i understand exactly where you come from
Old 02-12-2008, 02:33 PM   #29
chev74
Addicted to Chevy
chev74's Avatar
Hey guys! this is what i have gotten done so far. Its never exactly how you want it to be, but Im fairly satisfied. I just got done painting the bezel this afternoon after i got off work. The black is an ultra-flat black, and the others is a darker gray textured 'hammered' finish... Yes, its i spray job. Its all i can afford guys!
Old 02-12-2008, 03:00 PM   #30
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
Looks alot better than my gagues. Nice job.
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 02-12-2008, 03:20 PM   #31
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
They all look great. I have n't yet but you all are making me want to so bad. Someday when I get some time and some extra money I will get some in.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-12-2008, 04:46 PM   #32
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Looks good bud! You still going to paint the needles too?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-13-2008, 01:00 AM   #33
chev74
Addicted to Chevy
chev74's Avatar
yeah, thats the last part, besides installation. gonna run to Hobby Lobby and get some this afternoon
Old 02-13-2008, 01:23 AM   #34
mitch1965
mitch1965's Avatar
'BLE Burban, are those the stock gauges in your burb? I am looking to replace the gauges in my '85 K20 to add a tach and tripmeter. I really like your setup.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73
'01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10
mitch1965 is offline   Reply With Quote
Old 02-13-2008, 01:48 AM   #35
BLE 'BURBAN
With the exception of the tach/fuel gauge and the air pressure gauge, yes they are they stock gauges. Look for a cluster out of an '89 model or an early '90 model as they are cable driven.
Mine has a NP231 T-case with an electronic speedo so I had to do some MAJOR rewiring to get my set up to work for me.
Look here to see what I had to do with mine....
http://67-72chevytrucks.com/vboard/s...d.php?t=265731
Old 02-13-2008, 02:03 AM   #36
BLE 'BURBAN
When I painted my needles, I started off by masking the faces off with BLUE PAINTERS TAPE as it is very easy to remove and won't rip up the overlays. I then took the white spray paint to the needles and after that had dried/cured for 24 hours I took the red spay paint and sprayed a small bit into a cup then I used a # 000 paint brush to paint on the red. The reason I used spray paint instead of regular brush on paint is due to the fact that it's thinner and wouldn't be as heavy on the needles to end up throwing off the readings.
Old 02-13-2008, 03:00 AM   #37
mhicks
mhicks's Avatar
Looking Gooood!!!!!
mhicks is offline   Reply With Quote
Old 02-13-2008, 09:15 AM   #38
ton*loc
ton*loc's Avatar
this is kinda off topic but can i swat in the guage set with a tach if i didnt have one stock ?
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 02-13-2008, 10:22 AM   #39
BLE 'BURBAN
Sure can!!
You'll just have to repin the connector on your harness to matchthe replacement gauge, run a lead to your dist tach terminal and hook up the +&- leads for the tach.
Old 02-13-2008, 11:49 AM   #40
ton*loc
ton*loc's Avatar
Sure can!!
sweet
MMA RECORD 24-5
