Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-03-2008, 11:37 AM   #1
Super73
Super73's Avatar
Re: Ran my 72 at the strip
Couch,
That is light.. I would think mine should be lighter being an LS1/4L80E. Last time I weighed it, it was 3,840 with me in it and a full tank. Since then I lost the front bumper (had a roll pan in the rear) put draglites on it, yanked the heater and swapped back to manual brakes.
Your's is still going to be lighter...
Super73 is offline   Reply With Quote
Old 03-03-2008, 01:25 PM   #2
Montini
Montini's Avatar
I'm running a 383 stroker and th400 with no heater box.
Montini is offline   Reply With Quote
Old 03-04-2008, 11:19 AM   #3
Couch
Daily Driver
Couch's Avatar
Originally Posted by Super73 View Post
Couch,
ive been told theres no way its that light at the track.then i bust out the slip that says it. i should upload it into my photobucket just in case, i coulda proved myself on a previous board. by wooden floored bed.its just a piece of plywood. the original wood was shot. so that shed like 50 to 60 lbs. i'd guess
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 03-04-2008, 06:29 PM   #4
Montini
Montini's Avatar
I'm hoping to get it in the 7's without spray. First I need to find out why the 2-3 shift is hesitating, the aftermarket dipstick is not accurate. When it reads full on this stick it is way overfilled. The pan on it is deeper than any th400 I've seen, it is a stock stamped steel piece. I was told this is a hd version that was put in 3/4 and 1 ton models. I am wondering if the fluid was a little low, would it cause the hesitation? If the fluid was a little high would it foam and cause the hesitation. It is not slipping at all, launches very hard and chirps 2nd but hesitates going to 3rd. Anyone ever had this problem?
