Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-10-2008, 08:45 AM   #1
bullwinkle
New Member
electric water pump & heater
Has anyone run a electric pump like CSR or others with heater connections? Is it possible to do?
I would like to run a sb electric pump and heater. I like the looks of the electric pump & electric fan. If you don't have air and don't run power steering I think it would have a nice clean look.
If anyone has ideas or pics I would appreciate it.
bullwinkle is offline   Reply With Quote
Old 03-21-2008, 03:05 PM   #2
larry may
Re: electric water pump & heater
Is there a picture you can post?
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 03-21-2008, 05:23 PM   #3
tommypic
tommypic's Avatar
would like to see one
tommypic is offline   Reply With Quote
Old 03-21-2008, 05:52 PM   #4
djracer
djracer's Avatar
I think it would work. I run a manifold and a remote pump.
http://67-72chevytrucks.com/vboard/s...151718&page=10
The fifth pic shows my setup! The pump says Goza on it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-21-2008, 06:28 PM   #5
lyrikz
PITbut
lyrikz's Avatar
Wouldnt running an electric fan and electric waterpump save you a decent amount of horsepower???
I have dealt with hondas all my life and one of the tricks i used to use was remove power steering and reroute the lines back into the rack so its a closed system.. Steering was a bit stiffer when parking, but i dynoed a 7hp gain from that... IT was power that was already there, i was just freeing up the parasitic drag. I would imagine if you got rid of that parasitic drag from that waterpump and fan, you could easily see a good gain on a v8? Right? :hug:
lyrikz is offline   Reply With Quote
Old 03-21-2008, 08:31 PM   #6
whatnow123
whatnow123's Avatar
Originally Posted by lyrikz View Post
Steering was a bit stiffer when parking, but i dynoed a 7hp gain from that... :hug:
Reading this I envision 7 horses turning a power steering pump just so we can have easy steering.. I know, I'm warped.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 03-22-2008, 06:27 AM   #7
djracer
djracer's Avatar
It helps a little
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-22-2008, 06:21 PM   #8
lyrikz
PITbut
lyrikz's Avatar
It did a few things actually. The steering was a lot firmer, felt alot better, and 7hp on a 200hp motor is HUGE man.... My honda motor was tweaked, and it would cost tons to get 3 or 4 hp out of anything. This 7hp dyno proven gain with NO cost involved was awesome....
I have a feeling that you would gain twice that on a v8... I might actually do a before and after dyno on that and see what comes up...
