Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-29-2008, 04:03 AM   #11
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by Blizz View Post
It's for a Blazer and I'd be in WAY over my head so I'd probably have some body guys do it on the side for me...but the floors are pretty bad and it's even gone up the seat supports which aren't in any pans that I know of. So this looks like the best way to go. I'd just hate to spend $120 more to just get the parts that I already have pre-attached. I'm sure I could handle that much. Btw, this complete floor replacement....pretty much has to be done off the frame correct?
If it is rusted into the seat pans, then yes full floorboard is the way to go. Careful tho, trucks don't have the crossbrace for the forward sear mount, like jimmies do, so save yours as you will need to reinstall it. I don't know if you can get it under the floorpan and on top of the braces that run parallel to the frame.
It may be possible to do it with it still on the frame, considering how the pan drops in from the top
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
