Old 05-07-2008, 08:21 AM   #1
75silverstep
KEEP ON TRUCKIN.
75silverstep's Avatar
Rookie here!!!!!!!
Hi there.A few questions for you air guys that im sure mightve been answered on here b4.But what the hell i need the help.Going to bag the front using slam specialties re 7s i think oh ya this is on a 75 stepside stock arms also.For the time being im going to go with the sloooooooooowwwwww way of using the schrader valve technique.one per each side .Im using 3in drop spindles and when aired down i need this to sit as low as possible.What should i use the solid plates to mount bag to or use a 1 1/2 bag mount.Oh ya it has the sway bar still on it should i keep it or ditch it ,not going to be driven to often...thanks for any advice and sorry for the long post.
1975 C-10 STEPSIDE (ALMOST DONE AGAIN)90 percent done wheres that other 10 haha .1994 GMC Z71 .
75silverstep is offline   Reply With Quote
Old 05-07-2008, 08:35 AM   #2
los-lowrider
los-lowrider's Avatar
Re: Rookie here!!!!!!!
I used this set and cut the cups 1/2". If you cut more you are going into rubbing problems between LCA and bag.
http://www.*****************/67-87Ful...rtBrackets.php
Best Regards from Germany!
www.los-lowrider.com
los-lowrider is offline   Reply With Quote
Old 05-07-2008, 09:24 AM   #3
75silverstep
KEEP ON TRUCKIN.
Hey there in germany ...Thanks for info.do those just sit in the control arm like a spring or do you weld them in..Will check back tomorrow im going to bed its 1142pm and 0430 comes quick.
Old 05-07-2008, 04:35 PM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Personally, i would use the upper plates. That's what I have, they work fine. You can also make them yourself - I did.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-07-2008, 04:56 PM   #5
75silverstep
KEEP ON TRUCKIN.
No talent when it comes to cutting metal or welding im a pre made type of guy haha..The one he showed in the post has a plate for the top and cup for the bottom..And what do you guys think about the sway bar..off to work be back later.thnx
Old 05-07-2008, 04:58 PM   #6
smashingchuck
Speaking from experience (and I just threw mine out) I would try to retain the sway bar.
78 Build Thread
4Runner Build
Old 05-07-2008, 05:45 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
There are several schools of thought on front bags and how they are mounted. I'll let the experts discuss their theories here.
I will suggest that you keep the sway bar. Air suspension needs the additional anti-roll control that it offers. You can buy a set of lowered brackets from ECE, or you can bolt the clamps directly to the frame. Either way will get you the additional clearance that you need.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-07-2008, 06:20 PM   #8
Frizzle Fry
Frizzle Fry's Avatar
I used that plate/cup kit. Works well. You don't weld the cup in. It's just sits in the arm pocket and is held in by the weight of the truck on the bag. I cut my cups down to a total height of 1.5" but your arms might be different. You will have to drill holes for the plate bolts. RE7's are a good choice. Definately keep the sway bar. I had to trim the ends off mine to keep it out of the bags when aired out. You may or may not need to, but definately check.
Frizzle Fry is offline   Reply With Quote
Old 05-07-2008, 07:30 PM   #9
jlaird
jlaird's Avatar
I've got lower plates if you wanted to go that route. Check my sig.
-josh
jlaird is offline   Reply With Quote
Old 05-08-2008, 08:12 AM   #10
75silverstep
KEEP ON TRUCKIN.
Eveyone thanks for all the info.Also i have bell tech lowered shocks will i need to move them at all..
