Old 05-19-2008, 03:49 PM   #1
skydiver
Just a fan.
skydiver's Avatar
Lightbulb Great rust remover
Just thought I'd share a new product I found for removing rust. Its called Metal Prep Dip Rust Remover and its made by Zep. I bought it at Home Depot. This stuff works great. I soaked by mater cylinder cover in it over night and the rust was completely gone by morning. No wire brushing needed. I am going to start using it on all my rusted parts.
skydiver
skydiver is offline   Reply With Quote
Old 05-19-2008, 04:01 PM   #2
Ol'Rover
Project: years too late.
Ol'Rover's Avatar
Re: Great rust remover
Does this come in 45 gallon drums?
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here.
Ol'Rover is offline   Reply With Quote
Old 05-19-2008, 04:27 PM   #3
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
How did you clean of the cleaner residue? Have painted anything after using the Zep product yet? I would like to see how that turns out.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 05-19-2008, 08:20 PM   #4
skydiver
Just a fan.
skydiver's Avatar
I have only painted small parts as of now and it seems to take the paint well. Only requires soap and water to clean after soak. Here are some pictures...as you can see it cleaned the master cylinder cover well. I didnt want to paint it yet to see how it holds up after some time. I put some oil on it to keep it from rusting again.
Old 05-19-2008, 08:22 PM   #5
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
wow.. now thats some results.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-20-2008, 01:48 PM   #6
tommypic
tommypic's Avatar
check this out from PowerBlock on rust removal
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 05-20-2008, 04:02 PM   #7
68gmsee
Active Member
68gmsee's Avatar
http://www.youtube.com/watch?v=ZhTZkvkivDQ
Wow! I've heard of this procedure but never seen anyone actually do it.
With this method, theoretically, you're only limited by the size of the container....
68gmsee is offline   Reply With Quote
Old 05-20-2008, 04:44 PM   #8
geoman
Good find guys! I just picked up some front end parts that I need to do this. I am going to try both and see.
1967 Fleetside, Sanford and Son Special
Ivory/Blue Vinyl, 350/TH-400/12-bolt
geoman is offline   Reply With Quote
Old 05-20-2008, 05:21 PM   #9
Alex Hayley
At the end of this video, the surface is described as "black". Does the surface have to be cleaned further other than just rinsed off or do you paint over the black?
Alex Hayley is offline   Reply With Quote
Old 05-20-2008, 05:35 PM   #10
nightmare
nightmare's Avatar
Considering that it's just water and baking soda, it may just need to be rinsed, then should be able to just paint right over that.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-20-2008, 05:43 PM   #11
jayharrell
jayharrell's Avatar
thats pretty handy info right there. i wonder if it would strip old paint and everything off some steelys
00 S10 2.2 Vin5
Old 05-20-2008, 06:32 PM   #12
Alex Hayley
Can anyone recommend a good battery charger(brand and/or model)?
Old 05-20-2008, 06:51 PM   #13
Luvlegs
Luvlegs's Avatar
I've done the battery charger deal on a number of parts - also some marine manifolds - it takes longer than "hocus pokus" but it does work. I also had to stop a few times and wire brush a bit so it knocked time off how long it would have taken. It didn't remove paint (as there was no rust under it) - I rinsed the parts and then wiped down with laquer thinner - primed and painted - going on 3 years, no rust came through so..... I just used an inexpensive charger (best way to desribe it, 6 and 12v charger - charge and jump settings as well as regular and deep cell. Didn't hurt anything but I was REAL cautious with the water and electrical.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 05-23-2008, 02:56 PM   #14
caminokid
Chevy nut
caminokid's Avatar
I am willing to try both. Both looks like they work good.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 05-23-2008, 03:06 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I've heard good things about Zep... now I just need to put them to the test!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-23-2008, 07:25 PM   #16
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Well I need to that and soak the whole entire truck in the rust solutions.
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 05-23-2008, 08:02 PM   #17
jayharrell
jayharrell's Avatar
lol... my luck, when i bought the stuff it, the lid would come off and spill all in the bed. I would make it home with half a truck.
00 S10 2.2 Vin5
Old 05-23-2008, 08:12 PM   #18
70' GMC
70' GMC's Avatar
I would be left with the frame, motor, transmission, and seat. At least it would get better gas mileage.
