Old 05-23-2008, 05:26 PM   #1
Boog
laying low
Boog's Avatar
manifold paint & underhood shine ?
I have a set of stock exhaust manifolds to put on and want to smooth them up and apply some paint. I plan to grind them down some but as for the paint I know Eastwood and some others have an exhaust manifold paint. My question is how long can I expect it to stay on. I don't think I want to spend for ceramic coating. This truck will not be a DD.
As for painting inner fenders, radiator support, etc, what do you prefer? Factory semi gloss black with body colored firewall.
Painting most everything under the hood body color.
Or using gloss black on the inner fenders and core support.
Bottomside of hood black or body color.
My truck will be sort of Admiral blue outside and the firewall is already painted gloss met black but I am not opposed to change. I am leaning toward continueing with the met black for inner fenders & core support.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-23-2008, 09:08 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: manifold paint & underhood shine ?
For something that looks really good and that should last for a very long time, I would use por-15 manifold gray. The one in the pic has not been fired up yet so it has not cured yet so is should lighten up some.
As for under the hood stuff, That is just a personal choice you have to make. I would use semi-gloss just like the General did.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 05-23-2008, 09:24 PM   #3
Sammy
Be care full grinding down the manifolds as they do crack easily.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-23-2008, 09:50 PM   #4
Boog
laying low
Boog's Avatar
I'm not wanting to make them completely slick just remove some of the bumps. That por 15 finish is like what I wish to have and hope it lasts a long time.
Boog
primer is finer
Old 05-23-2008, 11:33 PM   #5
65-72 chevytoys
65-72 chevytoys's Avatar
I sandblasted mine and then used the Eastwood stuff. I must not have prep it right because there was rust poping through with in two weeks.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 05-23-2008, 11:57 PM   #6
OhioDan
OhioDan's Avatar
I sand blasted mine and used heat paint. As you can see, I didn't do something right? Gonna check into that POR 15 manifold gray. I like that. I painted the inner fenders and the radiator support gloss black.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-24-2008, 12:39 AM   #7
Boog
laying low
Boog's Avatar
That's what I want to avoid Dan. Looking at your pic I see another place we can use por15. The master cylinder.
I am leaning toward gloss black on the inner fenders and core support as well.
Boog
primer is finer
