Old 06-15-2008, 05:20 PM   #1
truckn'
truckn''s Avatar
Re: Big window conversion?
Originally Posted by protrash64 View Post
I had body damage which prompted the conversion. Big dent had bent the interior structure and it could not be pulled. I have never seen the inside of a true big window......just cut mine out and clamped it together. pie cut the corners and spto welded around the wndow frame. Installed window. Tinted glass........
what is the purpose for the pie cut around the corners?
chevy, it's the american way
truckn' is offline   Reply With Quote
Old 06-15-2008, 05:36 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
The inner panel has to be pushed back to meet up with the outer lip. The corners have to be cut to allow this to happen. Cutting larger sections out allows you to make patches with a better contour.
Frizzle Fry is offline   Reply With Quote
