06-30-2008, 04:54 PM | #1 |
Senior Moment
Need Help with Vaccum Can
My new cam left me with very little vaccum. I've heard of hooking up an additional can to get more vaccum and make the brakes work, Any help would be appreciated.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
06-30-2008, 06:44 PM | #2 |
Re: Need Help with Vaccum Can
Get a vacuum pump that operates off 12 volts
69 Chevy 4x4 383 Power |
06-30-2008, 06:47 PM | #3 |
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-30-2008, 07:36 PM | #4 |
its all about the +6 inches
following the link that larry posted;
That's the one I had when i was over cammed for power brakes. Run manifold vac to the brass nipple, then from the other port, to the booster. |
06-30-2008, 07:54 PM | #5 |
I think it goes the other way Andy. The black fitting is the "check valve". The vacuum is applied to there. It keeps the vacuum in, so it doesn't bleed-off when you shut the engine off, and it keeps back-fires out. Then the brass fitting goes on up to the check-valve on the booster.
06-30-2008, 08:07 PM | #6 |
dislexia is a hctib. You are 100% right.
Hey, it was 10 years ago. |
06-30-2008, 08:43 PM | #7 |
You can't type LOL backward..........OAML
06-30-2008, 11:52 PM | #8 |
Senior Moment
How simple, Thanks
06-30-2008, 11:54 PM | #9 |
Senior Moment
How many inches are best to run brakes? I did a check and have ~12
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 07-01-2008 at 08:53 AM. |
07-01-2008, 08:53 AM | #10 |
Senior Moment
ttt
