Help with single headlight grille to composite
Hey guys. I've been looking around around and I want to convert my single headlights into composite style.
I have a '93 Sierra 2wd.. I'm pretty sure that I can find all the lights and a grille and whatnot at my local salvage yard. I also found a wiring harness at LMC trucks that will keep the low beams on when I switch to high beams for $30..so I might just order that...or also grab the wiring for the ones when i go get everything. Will the grille fit flush? I'm thinking of ordering a chrome grille off of LMC truck also, and just getting the lights, mounts, and stuff at the salvageyard. My brother said that i'd need to order some radiator support thing? which he said was about $50. anythoughts? Last edited by 93Sierra; 07-04-2008 at 11:07 PM. |
Re: Help with single headlight grille to composite
Any help?
1993 GMC RCLB | Arrival Blue | Leveled | Debadge | Demold | Colormatched | Roll Pan | W/t to Composite grille conv. | SOLD 2008 Chevy ECSB | Line-x | AVS | 3/4 Debadge | Z71 | Blackbear tuned | 35% Roll Ups | 2010-11 HD front end swap swap coming.. |
![]() Join Date: Jun 2007
I don't think you'd have to change your radiator core.
![]() ![]() Join Date: Jul 2002
I know folks to go the other way, composite to real headlights and don't remember them needing a core support. Unless someone else chimes in, the best I can think is that no you don't need it, but check while your stripping parts and see if there is anything that is mounted/welded to the composite core support that you don't see on the regular support.
Good luck and keep us informed in how it worked out for you.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 07-05-2008 at 09:41 AM. |
Alright. Thank you MonteSS454, and Palf70Step =] I'll try to tell you how she goes.
I've never even looked at how the grill is mounted on my trcuk, but I saw this and thought it might help. This place also sells the complete kit with grill and headlights, I just couldn't find it right away.
http://www.mrtaillight.com/product_i...bf68f5e459b69a |
![]() Join Date: Jan 2003
Check out http://www.jegs.com/i/Anzo/018/111004/10002/-1 . I put a set of these in my 98. They come with bulbs, headlights and mounting/adjusting assembly. The bulbs a low end, I put a set of Sylvania Silver Stars in.
2013 Ford F150 FX4 2006 Chevy Silverado 1500 1982 Chevy C1500 2020 Ford Explorer Limited 2008 Ford Escape |
I'd bet the core support doesn't need changed. When I started out on my crew cab project, I had just the single headlight on each side. Then I switched to the dual setup (sealed beam, not composite) and all the threaded holes were there. If I remember correctly, it seems someone told me that the composites and the quad sealed beams were interchangeable, as far as mounts go.
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels ![]() Who needs a car when they make crew cab trucks? |
Okayy. thanks everyone for the input.
Jeep & GMC thanks for that site. I think that those could come in handy.
The owner of that site has a cool diesel suburban and hangs out on the 88-98chevy section of the dieselplce.com
Hope it goes well, post some before & after pics. |
#11 | |
8 vehicles only 4 that run
![]() Join Date: Feb 2006
95 2500 350 w/ 3.73 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
#13 | |
#14 | |
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E. GMC Sierra Custom C1500 1983. Oldsmobile Dynamic 88 -65. Volvo V70 -02 and BMW 523i T -99. Harley FXDF -08 and Harley FXDB -10. Honda Dirtbike Dominator -97 and a couple of tractors. |
#15 |
no problem!
#16 |
Countdown Survivor
You don't have to spend the $30 on that "Hi 4" conversion kit, it's fairly easy to do with parts store stuff, and from what I hear the kit is not as good as a relay. I think I can get the relay number off mine and all the wiring info, when you get ready.
#17 |
Yeah, that would be great =] I'll let you know!
| Bookmarks |
