07-20-2008, 01:43 AM | #1 |
trans brake
just wondering if any body out their has install a transbrake in a th400 how hard is it do you have to pull the tranny out i just pick up a b&m trans brake with rev valve body trying to find some good pictures of instilling it b&m gives crap of instiction
07-20-2008, 10:31 AM | #2 |
Registered Truck Offender
Re: trans brake
There is more to it than just bolting in a valvebody. At least to make it survive there is. If your not familiar with the whole scenario I'd HIGHLY suggest you take it to a good trans shop and have the trans built for the brake. Most of the stock components will survive only a short time under the rigors of a transbrake launch.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
07-21-2008, 06:13 AM | #3 | |
Re: trans brake
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? Last edited by PA-IndianRider; 07-21-2008 at 06:21 AM. |
07-21-2008, 02:37 PM | #4 |
Re: trans brake
There are too many modifications to be done inside . It has to come apart . I run a Hipster brake . Nine years ago when I put my truck back together I did alot of research on this and one of my friends builds my transmissions . We have gotten it to where it survives pretty well . We usually tear it down once a year . Usually we replace a bushing or two maybe one or two clutches and steels . It is amazing how much stock TH400 parts can take . I can tell you alot of little tricks that will help it survive . Three good ones are, drilling out the center support bolt so more fluid can go to the second gear clutches , using a stock type wave plate in the case for second gear , and putting a good cross hatch on the sprag surface everytime you have it down .(these are for sprag survival) . Another important thing on a TH400 is high gear clutch clrearance ! Dont be afraid to put 100 to 110 thou of clearance in them . The reason for this is when the tranny is in low gear those clutches are turning 1.5 times engine speed backwards .
NHRA Super Street 469C It only runs 10.90 at 156 mph |
07-22-2008, 08:10 PM | #5 |
Re: trans brake
thanks
08-16-2008, 06:48 PM | #6 |
Re: trans brake
A buddy of mine tried the DIY route, ended costing more in the end.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
08-18-2008, 02:58 PM | #7 |
Re: trans brake
Need to take it to someone that knows how to build racing trans so you won't tear up all the other stuff
Built chevy tuff! |
08-20-2008, 01:16 PM | #8 |
mini truck racer
Re: trans brake
Just took the glide in to the shop for bell housing change and freshin up . Grand total $150 . Not worth messin with in my opinion .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
