Old 08-04-2008, 11:07 PM   #1
Andy4639
Old member
Andy4639's Avatar
Finally installed
OK,
I know what your going to say they don't look right and your correct they don't. They don't make a kit for our trucks so I guessed at the kit I needed and then ordered some more rubber bushings also that where thicker. I think I need to shave some of it off to make a better fit. I cut about a 1" off the bottom bolt so it wouldn't poke a hole in the bottom of the bag also. Haven't drove it yet since I just finished it up to this point tonight.
I ran 2 seperate lines for them so I want have the pressure swaping from side to side. I ran each line back through the frame rail then used the 2 air valves to mount my tag.
First is with caps on:
Next with them off:
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-04-2008, 11:26 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Finally installed
Any reason why you didn't just run a bag by itself? (without the factory rear spring) There are plenty of people on here running a pair of Slam Specialties RE-7's on schrader valves with good results. Just curious.
Keith
Convert to disc brakes.
Old 08-04-2008, 11:31 PM   #3
kevindtimm
like lolife said, the bags are meant to be run without springs. that's the point
kevindtimm is offline   Reply With Quote
Old 08-05-2008, 12:25 AM   #4
SCOTI
SCOTI's Avatar
Some bags are, some aren't.
The ones he used are helper bags that go inside of a coil. Seems like it would be easier to just swap the coils for bags..... but there's usually more than one right way to get things done.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-05-2008, 05:35 AM   #5
Andy4639
Old member
Andy4639's Avatar
I needed the air bags to help with it bottoming out. Yes I guess I could have gone with just a air bag rear but I have very limited knowlege of doing all that. This was easy no mods and I didn't have to make any brackets are anything to hold them on with.
It was cheap also,less than $150.00 for everything.
I wish it was bagged all the way around though. Maybe one day!
Old 08-05-2008, 07:04 AM   #6
70c10
67-72 Addict!
70c10's Avatar
I don't know jack about bags but the air valves are cool
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-05-2008, 08:19 AM   #7
Andy4639
Old member
Andy4639's Avatar
70c10 Re:
Thanks I almost didn't do them. I was going to leave it behind the bumper. I think it looks cool too!
