Old 08-04-2008, 08:36 PM   #1
stump
custom hood cowl?
a kid from school on his 88+ chevy just cut the hood down the center in two spots from the back almost to the front, lifted it about 4 inches and bent it a little and then welded sides in, didnt touch the braces underneith.. im thinking about doing it? good idea or badd
stump is offline   Reply With Quote
Old 08-04-2008, 08:39 PM   #2
impalamark
impalamark's Avatar
Re: custom hood cowl?
Depends
how good are you at cutting
fabricating
welding
and finishing sheet metal ?
Mark
impalamark is offline   Reply With Quote
Old 08-04-2008, 08:45 PM   #3
Eyegore
What Hump?
Eyegore's Avatar
Hot Rod Magazine an article in the 80's with a early model mustang where they cut the hood as you described. They lifted the trimmed pieces up with spray paint lid caps to give the same height. The then used a rolled piece of metal to patch in cutting caty corner to give the same roll on both sides. I know someone on this board talked about it last year, perhaps you can do a search and find it.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 08-04-2008, 09:40 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
WELL THANKS A WHOLE H-E-DOUBLE-HOCKEYSTICK LOT!!!! As if I didn't have enough idea's I can't afford to do, you just went and gave me an idea as to how to set up a RAM AIR OLDS 442 STYLE hood scoop on my burb. JEEEZ!!!! More money I gotta make now!!!!
Where's my scanner/printer at? I gotta get ta printin'.......
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 08-04-2008, 10:10 PM   #5
stump
send me some of the money you print.. and ill fill your ink for free
Old 08-05-2008, 08:19 PM   #6
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
I’m a sheet metal welder by trade and I wouldn’t do it. The heat warpage will kill you, and if you can’t do the work yourself the cost would be more then one from LMC. The only way I can see it is to spot weld and bondo. If I were to do anything I would cut your hole and fiberglass your cowl in.
Having said that I do plane on making my truck an extra cab for no other reason then I can. So don’t let me talk you out of it.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 08-05-2008, 08:22 PM   #7
spr85gmc
spr85gmc's Avatar
i have had this idea for the longest time but warpage and a bad out come worry me but i say go for it and post hella pics.
spr85gmc is offline   Reply With Quote
Old 08-05-2008, 08:37 PM   #8
stump
well idk.. i can get it welded for free (dads works at a garage) so that will be fine..
Old 08-05-2008, 08:55 PM   #9
ont_guy_38
ont_guy_38's Avatar
I would certainly would practice on an old hood first and if that goes ok then do it but i myself think it would turn out to be one heck of a lot of work to get it to look good
ont_guy_38 is offline   Reply With Quote
Old 08-05-2008, 09:15 PM   #10
57larry
I'd like to see some pics or a tech article. cool idea
57larry is offline   Reply With Quote
Old 08-05-2008, 09:17 PM   #11
andresco50
andresco50's Avatar
Good idea but you have to cut it very carefully very straight, and weld it very good... Post some pics of your friends's hood!!!
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 08-05-2008, 09:36 PM   #12
Eyegore
What Hump?
Eyegore's Avatar
the article was in hot rod on an early model mustang, I wish I kept the article.
Lil red 86 c-10
99 Sub
Old 08-06-2008, 01:39 AM   #13
sailed2japan
Jonny
sailed2japan's Avatar
Jump in with both feet, if it doesn't work, then buy onefrom LMC, but try and save a little $ whenever you can. I'm going to build on for my 64 because I want to keep the "V" on the hood. Besides, a little warpage is nothing a skim coat of bondo won't fix.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 08-07-2008, 01:08 AM   #14
ARAMP1
ROCK*STAR
ARAMP1's Avatar
You mean something like this?
ARAMP1 is offline   Reply With Quote
Old 08-07-2008, 12:21 PM   #15
stump
skinnyer then that.. like half the size. and 4 inches in the back and im gona leave the front attached and just bend it
Old 08-07-2008, 02:27 PM   #16
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
ARAMP1, I was looking for the post on that dually on my forum to post it today...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-07-2008, 02:37 PM   #17
Moostifer
a fool with no money
Moostifer's Avatar
I would only reccame, recomen, recc.... I would only advise the best of body workers to do this... I thought I was pretty good until I tried to tackle that monster... save your pennies, and hours upon hours of spot tacking, grinding, bondo-ing for something that "looks o.k." the further off you are.
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 08-07-2008, 03:14 PM   #18
spr85gmc
spr85gmc's Avatar
http://www.stylintrucks.com/parts.as...tfamilyid=3168 i imagined something like this would look sleak as ever
