Re: Vintage air install
Hey Boatpuller how about some pictures of the engine compartment? I'd like to see how things mount up under the hood. Thanks!
My Truck's not leaking its marking its territory! Last edited by 87Bob; 08-29-2008 at 03:23 PM. |
i'll snap a couple new one's and post em this weekend Bob.
" Never look up a dead dogs butt." ![]() |
#3 | |
Frank
Born and proudly residing in a Red State ! |
here is mine. I had it installed at the body shop while it was apart after the wreckI was involved in last year. I helped with it some. it really was pretty strait forward, instruction were easy to follow. works & looks great.
75 GMC C-15 short/step factory 454, lowered |
Why did they install the compressor on the left hand side? On the right the lines would be shorter and not cross over the engine.
My Truck's not leaking its marking its territory! |
than I would have had to buy new alternater brkts(already had these). Also, the sure fit kit for this truck mounts the compressor on the drivers side, if it were mounted on the pass. side, I would have to toss the lines that come with the system & make all new lines
#7 | |
Thanks Boat. Im pleased with it. If you mounted the compressor on the pass. side, the line they give you coming out of the driver side of the radiator support going to the compressor from the condensor coil would have to be modified to go back over to the passenger side. John
75 GMC C-15 short/step factory 454, lowered Last edited by stepside454; 08-31-2008 at 11:54 AM. |
