Old 09-28-2008, 01:50 PM   #1
Pont406
will it last another 5-10 years?
I see a lot of posts about roof sealer and problem caused by it. I never looked at seam sealer on my cab untill now. It's cracking bad but I am sure it was this way for a while. If I don't do anything about it do you guys think it will last maybe another 5 years or so?
Pont406 is offline   Reply With Quote
Old 09-28-2008, 02:25 PM   #2
KMACD71
KMACD71's Avatar
Re: will it last another 5-10 years?
I would get a garden hose and run some water on your drip rail to see if you get water inside the cab.It looks like some of the cracks could take in some water.Just my 2 cents.
KMACD71 is offline   Reply With Quote
Old 09-28-2008, 03:30 PM   #3
Pont406
it's only get water when I wash it, once in a while. No leaks inside.
Old 09-28-2008, 05:34 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Wow, yours is in good condition! Ours is barely left.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-28-2008, 05:53 PM   #5
john
member #16
john's Avatar
The only problem is rust between the top and roof. You wont see it until it comes through. I would consider some kind of temporary fix until you are ready to do the body work. If the truck doesnt sit out in the weather you are probably good for awhile.
john is offline   Reply With Quote
Old 09-28-2008, 05:56 PM   #6
Omnivec
Why do you need it to last 5-10. That is pretty vague.
67 3/4 Lwb Step side X San Diego County truck
70 3/4 berb was 402 Th400 Dana 60 now just the dana
70 3/4 lwb Fleet Choptop bagged th350 no eng yet
79 rx7 Wide body 350 TPI t5 flat black(The interceptor)
64 comet mounted on a 93 Thunderbird chassis.
Omnivec is offline   Reply With Quote
Old 09-28-2008, 06:16 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
being that it rains in LA only once in a while, I doubt you'll have any poblems.
Old 09-28-2008, 07:34 PM   #8
I bought a truck out of El Cajon and it had sun baked seam sealer there.It ended up with a rotted header panel inside.Why wouldn`t you just fix it?The sun belt trucks don`t rust like rust belt trucks and have lasted way better.But,your time is coming.Rustbelt trucks rust from the bottom up and yours will rust from the top down,just slower.I`d grind that out,get to clean metal,seal,prime,and paint with white paint.My truck from Modesto had totally cracked sealer,too.I fixed it before it made a bigger problem.We expect rust here and baby or trucks to make them last.You guys take it for granted because you`re unfamiliar with it.You may have a 50/50 chance of it not becoming a problem.But,I`d act on making it last forever.Why take a chance on letting another get too far gone?
Old 09-28-2008, 08:11 PM   #9
Pont406
At first I sought it was a bondo repair from the po. After reading here I know what it is. I am afraid if I touch the body it will turn in to a frame off restoration. Sometime next year I will get to it. Right now I am doing a motor upgrade with some suspension work.
Old 09-28-2008, 08:39 PM   #10
clay68c10
clay68c10's Avatar
I'd clean that stuff out and reseal it. If you don't get a perfect color match on the roof, it's not that visible. By the time you notice rust coming thru, you'll have some major repair to do.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-28-2008, 08:53 PM   #11
Green Machine
Green Machine's Avatar
To hold our C20 till paint time, last year we masked it off about 3/4 inch from the edge and used some gloss white rustoleum and a brush to fill the cracks and seal it up until we can do it right. Looks good and no one has ever noticed the difference. Took 2 coats, one to seal and one to level it out.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 09-28-2008, 09:44 PM   #12
hotrodxy
hotrodxy's Avatar
i would put a coat of white seam sealer on it till your ready to do the body work, that should last about 5 years
1967 LWB 4speed-current project
1970 LWB 3 speed -stolen
1980 Z28 - sold
1968 Barracuda Big block- sold
1969 Firebird 400/400-sold
hotrodxy is offline   Reply With Quote
Old 09-28-2008, 09:53 PM   #13
463
463's Avatar
i just used the standard drip or seam sealer in the regular calking gun. cost $8.00 to $10.00. use gloves to finger fit to my liking - let dry prime & paint pics
Trueman
463 is offline   Reply With Quote
Old 09-28-2008, 09:54 PM   #14
68C15
blood type; Retumbo
68C15's Avatar
why settle for 5 to 10 years? I am looking for another 40 for mine.
68C15 is offline   Reply With Quote
Old 09-28-2008, 11:09 PM   #15
pat123
Pat
pat123's Avatar
Do you have to put a thick bead of sealer on the drip rail? like it was stock
pat123 is offline   Reply With Quote
Old 09-29-2008, 05:56 AM   #16
I would.You want the water to flow out and not lay in there.I use 3M Body Seam Sealer and you can mike the paint into it.My truck is white and I chipped it out,used an abrasive fiber wheel,masked off the top and below,rust arrestor,sealing primer,removed masking on top,and spray bombed Gloss White spray bomb.I scuffed over the edges with a fine Scotchbright pad and liquid clay barred the whole truck just to preserve it until restoration.
Old 09-29-2008, 10:04 AM   #17
Ackattack
Ackattack's Avatar
Just shave the drip rail, and then you don't have to worry about it
Ackattack is offline   Reply With Quote
