Rear Shock Relocating
Hey everyone i am pretty new to the site. I am going to get back working on my 1972 c10 short bed and i am going to do all the work myself and try to cut i little cost. I am lowering the back end of the truck 6 inches. I have to relocate the shocks and i need some pics of where the shocks mounts need to be moved. I am going to cut off my old shock mounts and just move those to the right spot to get my shock at the right angle. I am also going to make my own pan hard bar out of some 1 1/4 tubing with tie rod end joints in the ends. I need a pic of where this needs to be attached to the right side truck arm. i see that ece makes nice kits but i think i can save a little money doing it myself. please pics will be great or do i not even need to relocate the shocks. i am going to use kyb shocks. thanks a bunch for any help.
#2 | |
Re: Rear Shock Reloating
Sweet thanks a bunch do you have any suggestions on the trailing arm of how to do it. i see that when you order the one from ece it goes from the from to the lower trailing arm do you have a easy way of doing this let me know thanks.
#4 | |
If so, I've done it 2 different ways. For mild drops (4~6"), plate the inside of the pass side trailing arm w/some 3/16 min thickness steel to attach a mount to. Purchase a long bar or extend the factory bar to go from the OE driver side mount to the pass side trailing arm. CPP has revised their Super Track Bar kit to work like this & I feel it clears everything pretty good. If the drop is more than 6", I build the panhard bar mount into my lowering block. On my truck (RE-6 bags bolted directly to the frame/t-arm + 2" blocks) this puts the panhard bar parallel to the ground @ ride height which is optimum.
