Old 02-18-2003, 06:11 PM   #1
Bigtyme
Front Drop
I put in 3" drop spindles and 2" drop spings in the front of my
82 swb GMC for some reason the right side in a little lower than the left side with a hint of negative camber. Would a front end alignment solve the difference in height.
Thanks,
Martin
Bigtyme is offline   Reply With Quote
Old 02-18-2003, 06:19 PM   #2
low 84
low 84's Avatar
the alignment is just going to correct your camber. it will still be lower on one side. that is a common problem whne droping trucks. my passenger side is about 1/2 lower.
how much lower is it on one side?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-18-2003, 06:21 PM   #3
Low87
been here longer than Liz
Low87's Avatar
Interesting, I don't have this problem. Seems like the problem would be in the springs, but if they're new I don't see why.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 02-18-2003, 07:22 PM   #4
Tom
driving is in my blood
Tom's Avatar
One side seems to be a little lower then the other on my 79 now that I put the 3" spindles on. I had the 2" springs on for some time and it was even. Im thinking maybe the springs arent sitting correctly in the perches when I put everything back together.
Old 02-18-2003, 07:24 PM   #5
swervin ervin
swervin ervin's Avatar
Mine's about a 1/4" or so off. There are a lot of things that can cause this. After driving awhile, it will probably settle and level out a little more. One thing I noticed, which you proabably all have, if one tank is full, and the other empty, it will be off. Fill up both tanks and check it.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-18-2003, 07:26 PM   #6
Bigtyme
Spindle Defects
I was once told that dropped spindles can be shorter than one another......whether it's true I don't know
Old 02-18-2003, 07:38 PM   #7
Tom
Tom's Avatar
Re: Spindle Defects
Sure they can, if quality control sucks where they are made. But then all spindles would come out that way, and the company would get a flood of complaints.
Old 02-18-2003, 08:00 PM   #8
RockHQ
ROCKET POWER!
RockHQ's Avatar
I'm curious to know if anyone's tested how the weight actually is distributed over the wheels on a fairly stock truck, ie. put scales under each wheel and written the results down?
-Axle
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 02-18-2003, 08:38 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I am when mine gets closer to being an actual truck... ZIP IT MIKE!!!!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-18-2003, 09:29 PM   #10
apstguy
LED King
apstguy's Avatar
-Axle
The sticker for the weight has the front & rear but not all four wheels. I'm assuming it is 50/50 with both gas tanks full and no cargo from FL to FR or BL to BR.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 02-18-2003, 09:40 PM   #11
swervin ervin
I wasn't going to say anything. You act just like you know me or something.
Old 02-18-2003, 10:57 PM   #12
RockHQ
ROCKET POWER!
RockHQ's Avatar
Don't trust stickers. It can be a far cry from 50/50, easily. But as soon as i get my truck back into a drivable condition i'll see if i can measure the exact weight distribution (truck weighs 2480kg or 5460lb according to my VSR = vehicle specific registry)
Old 02-18-2003, 11:15 PM   #13
apstguy
LED King
apstguy's Avatar
I didn't say that very clearly, Let me try again!
I think that the weight distribution on the rear axle is 50/50 from the right side to the left. Vice versa for the front two tires. The split from front to rear is NOT even close to 50/50.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 02-19-2003, 12:04 AM   #14
solidaxel
solidaxel's Avatar
I'll be waiting to hear the weight of each front wheel, as mine is 3/4" lower on the pass. side measured from the center of the wheel well to the pavement. Thought about a 1/4" donut under the front right spring, but am still thinking about it !!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-19-2003, 02:44 PM   #15
Low87
Low87's Avatar
My name's Greg, so...................When is that going to be??
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 02-19-2003, 03:50 PM   #16
RockHQ
ROCKET POWER!
RockHQ's Avatar
Actually, you said it quite clear the first time and i understood you completely, but i still say the weight distribution for example on the rear axle from left to right might not be an even 50/50. How close, i don't know. It could be only a few lbs off, or a lot more. Anyway, hope we'll find out.
Old 02-19-2003, 06:10 PM   #17
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
i have easy access to a scale guys if you wanna know i can do it. i have dual tanks and a 2.5/4 drop. only thing is that i have a big steel toolbox in the back...dont know how much it weighs. just holler and ill weigh each wheel seperately. oh, also remember that in 81 when they redid the front ends they lightened it a lot so that will change weight distribution.
~1980 c10 chevy scottsdale~
~2.5/4 drop 305/th350c~
c10scotty is offline   Reply With Quote
Old 02-19-2003, 07:04 PM   #18
Captkaos
Captkaos's Avatar
In that case about the time you bag your truck.. (wonder how long that gives me......)
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-20-2003, 11:00 AM   #19
Low87
Low87's Avatar
LMAO, you've got a good two years.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 02-20-2003, 05:26 PM   #20
Captkaos
Captkaos's Avatar
That was WAY too easy..
Chris Lucas
1973 Chevy C-10
Captkaos Customs
