Old 10-21-2008, 12:42 AM   #1
Ford Assassin
Ford Assassin's Avatar
Question Externally Regulater to Internally Regulater Conversion
Hey guys, I am finishing up my LSx 5.3 conversion in my '69 C10. Well I dropped in the battery and hooked up the terminals only to find out I don't have most of my electrical working. After chasing a few wires with a test light I realized I am not going through my external regulator anymore. My alternator has a single power post on the back, so basically its a one-wire alternator.
I did a quick search and found out that several vendors sell conversion harnesses for $20+ shipping. Myself being a cheap guy (especially since I am over budget as it is on this swap) I figure I can make my own jumpers to create the same thing.
So does anyone know what I need to do to convert this thing over?
Any help is thanked in advance.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 10-21-2008, 02:49 AM   #2
El Jay
Gone to greener pastures
Re: Externally Regulater to Internally Regulater Conversion
Okay. I'm completely computer illiterate. So I can't post a direct link.
But, KRUE has taken a huge amount of time to compile a whole mess of FAQ's and their answers.
Just "cut & paste this to "SEARCH" near the very top of the page.
External to Internal Voltage Regulated Altenator Conversion
It will come up in about the 3rd post in his total posts.
I hope this helps a bit.
BTW, I used this to convert to an internally regulated alternator.
It's easier than all get out. And other than the cost of the alternator, it costs about, maybe $6.00, if that. About $5.00 was for a "replacement plug" for the new style alternator. (available @ any decent, or mediocre auto supply).
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 10-21-2008, 07:01 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
This one is for the internal regulated 12SI that most people have. If you have a one-wire then just hook a 10 gage wire to the terminal on the back and run it to the battery positive post.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-21-2008, 10:03 AM   #4
Ford Assassin
My alternator is the latest design. In its intended application (and the way its currently setup in my truck) it has a single post that runs a 8 gauge wire to the + side of the battery. Then it has another connector plug that runs directly into the factory computer wire harness. I am assuming the computer controls the regulator in this case.
I don't have the two other 'tabs' like most other 10si and 12si alternators it makes things alittle harder.
Cable
