Old 11-01-2008, 10:00 PM   #1
pete29
do i have to much trani fluid in trani
when i put the truck in drive it takes right off and spins the tire then i try to stop it and it kills it, the engine is never running vey fast even when it takes off. wondering if i have to much transmission fluid in and i can't check it since i can't run the transmission to warm it. what is the easiest way to take some out.
pete29 is offline   Reply With Quote
Old 11-01-2008, 10:16 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: do i have to much trani fluid in trani
drain it, replace the filter and refill with the appropriate amount.
It sounds to me more like a carb problem though...
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-02-2008, 10:31 AM   #3
Long Roof
Old School, New Style
Long Roof's Avatar
Never heard of such a thing being caused by to much fluid. Sounds like a broken torque converter maybe. This would happen with a 'lockup' torque converter if it wasn't unlocking.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 11-03-2008, 09:14 AM   #4
pete29
anyway to unlock it without taking it out.
Old 11-08-2008, 08:38 AM   #5
53burb
53burb's Avatar
if it is a lock up tranny, then it would have a couple of wires going to the tranny, unhook them, that will disable the lockup function....
53burb is offline   Reply With Quote
Old 11-08-2008, 09:42 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
What exactly are you working on? What truck? What year? What transmission? 3 speed auto? Auto w/ overdrive? Got any pics of the engine?
Keith
Convert to disc brakes.
Old 11-08-2008, 11:22 AM   #7
pete29
72 gmc 350 v8 with 350 turbo Has low1 and low 2, also is 4wd
Old 11-08-2008, 12:02 PM   #8
fine69
fine69's Avatar
Sounds to me like your engine idle is set too high.
Start it, let it run for 20 minutes. Then while its in PARK check the tranny fluid level.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
