Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-02-2008, 03:16 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Re: What are you using to heat your garage?
Originally Posted by cdowns View Post
heat my garage?i turn off the air conditionier
Ha, nice.
Originally Posted by vectorit View Post
The propane heater in the garage es no bueno!
See about getting a duct routed off your house furnace to the garage, and install a good damper so you can close it tight when not using?
Ya, i figured it wasnt very good to do that.. I might look into that seperate duct into the garage. That shouldnt be to hard to do.
Originally Posted by DirtyLarry View Post
I am using a Mr. Heater 45,000 BTU Garage Heater from Northern Tool and Equipment to heat my 1,000 ft detached garage. This will be the 3rd winter with it. I haven’t had to fire it up yet this year as it is still getting in the 80’s in November! The very first winter the igniter circuit board went out right away and the Mr. Heater folks were very helpful in expediting the parts to me right away. Other than that it works great and haven’t had any other problems since the first year…..knock on wood.
http://www.northerntool.com/webapp/w...7961_200307961
That looks like a good option. Was hoping to spend a bit less then that.
Originally Posted by chevyboy55 View Post
I use one of those heaters that go on top of a propane cylinder.It will heat me but not the shop.
im fine with the cold, i just cant paint when its to cold out there... Thats my problem. THat heater says it was not for indoor use. I was going to get the dual heater.
Originally Posted by Ackattack View Post
I don't have any heat in my 900sq ft attached garage So I just wear a sweatshirt and gloves and make do. I might have to figure something out if I want the truck finished by march though. I guess I have one of those 1000 W Halogen lamps that puts out some heat, but that's not it's sole purpose obviously.
ya, im not tryin to keep me warm, just my metal. ahaha..
lyrikz is offline   Reply With Quote
Old 11-02-2008, 03:19 PM   #2
68chevy68
68chevy68's Avatar
coveralls.....
68chevy68 is offline   Reply With Quote
