Old 11-12-2008, 12:19 AM   #1
Houston54
Re: hood brace repair
That area rots out because the brace is a hat section channel and traps all the dust/dirt at the lowest point. Of course it absorbs and hold moisture so this rots the brace out from the inside. It is a fairly easy fix with the hood off the truck. Remove all the rotted material, treat the inside area with a rust converter and prime/coat the heck out of it once that drys. Then weld in a replacement metal piece and grind to taste. Just watch the heat build up as it will warp the hood skin.
Houston54 is offline   Reply With Quote
Old 11-12-2008, 12:37 AM   #2
50adrod
50adrod's Avatar
luckily both hoods have rot on different sides so i have a donor. it comes out very easily 3 rivites and the center conector and its out. yes it is rusted badly on the back side where it holds moisture. thanks
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
