![]() Join Date: Jan 2007
Corvette Ram Horn Purchase Question - yes another one
For the corvette ram horns (2.5" outlet) - do I just need to buy the same part number (674503) for both sides and then use a cut off wheel and a grinder to shave down the extra brackets on them...
Anybody have a before after picture of them for the mods they made to clean them up for install? |
Old Skool Club
![]() Join Date: Jun 2001
Re: Corvette Ram Horn Purchase Question - yes another one
Good question. The ram's horns that I remember had the extension in the casting on the driver's side to mount accessories. But, that was before the heads were drilled/tapped. I have several sets in the garage, but not the larger diameter outlets that the 300-horse 327 engines had.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Yes, same part number on both sides. Saw/grind off the extra bosses if they are in the way or you want a better look.
Tim |
#4 | |
![]() Join Date: May 2006
#5 | |
Tim |
bump for pix - from anybody to show the portion that was cut off...
Thx. |
