Heater problem
It's getting really cold in Deer Park! It should reach -20 before Friday and I like driving my blazer around so I need to get the heater fixed. It worked fine two years ago, but it sat for about 2 1/2 years until I put a new motor in it. I hear the fan blowing but don't feel any air coming out. Any suggestions?
Re: Heater problem
Some mice may have found a new home, thats what I found when air didn't move
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
SKINNY TIRES RULE!
Re: Heater problem
Pretty common to have mice nesting.
Also, I've had problems with the squirrel cage getting stuck so the fan sounds like it's running, but no air is coming out. ![]()
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Re: Heater problem
Thanks for the help! I will take it apart and see what I can find out!
Re: Heater problem
Darn mice! They made quite the nest in there! It wasn't that bad getting it taken apart, cleaned out and put back together. Now everything works great!
#6 | |
Re: Heater problem
![]() Gotta love those racket wrenches Bouncy
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-18-2008 at 12:16 PM. |
SKINNY TIRES RULE!
Re: Heater problem
I just stole that picture off the web. I'm not even sure if it's out of our trucks, but it looks similar.
Re: Heater problem
Sure looks correct to me, but what do I know...LOL
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-18-2008 at 01:45 PM. |
Re: Heater problem
FYI, pass hood hinge must come off in order to pull the fan and it's still a tricky twist to get the compartment ahead of the core, which is where nesting usually occurs.
Is there air on cold? if not then definitely check that the fan is turning. Might also confir that cables are moving diverters, as you may have a nest AND abroken diverter so the air is always going into the heater core. Basically , take it apart i would say you can take the front to sections of the inside boxx off relatively easily, and likely tell where your problem is (in fact pulling the rubber cover for the heater cable will let you see if the fan works.
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
