#26 |
Re: Hard to start
1969 K/10,
You say it has a hard time starting - what are the symptoms? Do you have to give it gas, does it sputter, backfire, etc?
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone ![]() |
#27 | |
Re: Hard to start
Usually it is one hit and its started, but when its warm, it struggles to light.
1969 red k/10 with sb350 4.11 gear ratio, front disk, 3 speed automatic Last edited by 1969 k/10; 01-02-2009 at 10:18 PM. |
#28 | |
Re: Hard to start
HomerJ
#29 |
Re: Hard to start
I went through the same problems with my 10.6:1 406. I likes a lot of advance and has longtubes, so what fixed my problem was getting a good heat shield and then getting a 900amp cold cranking battery. The new battery helps turn the truck after the compression has built up. The truck starts immediately.
If your truck is warm and it starts but kind off sounds like it is lean/stumbling then it is a choke issue.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
#30 |
slims 68
Re: Hard to start
Carb could be heat soakin too. May need a good phenolic carb spacer.
May want to check the mechanical/vacume advance too and make sure they're not sticking.
68 c10 LWB, blown 454 ![]() 06 Chevy Cobalt SS supercharged 2.0L 08 Chevy silverado crew cab 1/2 ton 2wd 5.3L, she wont let me put a supercharger on it. Last edited by Tmiller; 01-03-2009 at 09:18 AM. |
#31 | |
Re: Hard to start
I still have no idea whats going on. I'm starting to blame the edeljunk carb.
1969 red k/10 with sb350 4.11 gear ratio, front disk, 3 speed automatic |
#32 |
slims 68
Re: Hard to start
Yup I had an edlebrock once, only once. They never seem to tune out.
What process did you use for the idle air mixture, I found by mesuring vacume seemed to make it run the best. Hey just remembered, pull those mixture screws and clean them and their seats out good, I remember having to do that frequently to keep it idling right.
68 c10 LWB, blown 454 ![]() 06 Chevy Cobalt SS supercharged 2.0L 08 Chevy silverado crew cab 1/2 ton 2wd 5.3L, she wont let me put a supercharger on it. Last edited by Tmiller; 01-09-2009 at 08:34 AM. |
#33 |
Re: Hard to start
Ya i'm not to good at getting this carb. in tune.
#34 |
I wish I was a cowboy
![]() Join Date: Apr 2008
Re: Hard to start
Hey K10: bring your truck to the meet this Saturday, and I'm sure between all the guys there we can get that thing singin'!
NorCal Mini-Meet
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
